Hi all,
I am working on a project with two Arduino uno's they both have an dragino lora shield attached.
The main goal is to create a server and client.
On the client side I have an battery powerbooster attached where a Lipo battery of 3.7V is connected. On port A2 I measure the voltage of the Lipo battery
On port 3&4 I have a Ultrasonic distance sensor connected.
Readingout the value from the sensor is working only the cyle time of the loop needs to be short 100ms.
On the server side I have an 0.91" Oled Display connected this is working with I2c on port A4 and A5 with a powersupply of 3.3V.
Everything works like it should be, only the uno of the serverside is crashing everytime after a few
seconds. This happens randomly sometimes it works longer.
And I can't find the point where its going wrong.
Source Client
#include <SoftwareSerial.h>
#include <SPI.h>
#include <Wire.h>
#include <RH_RF95.h>
RH_RF95 rf95;
SoftwareSerial mySerial(4,3); // RX, TX
unsigned char data[4]={};
float sensorValue;
float rawValue;
int min_width = -6;
int num_digits_after_decimal = 2;
char databufSensor[10];//20 bytes
char databufBatvolt[10];
mySerial.begin(9600);
if (!rf95.init())
Serial.println("init failed");
rf95.setFrequency(868.0);
//rf95.setTxPower(23, false);
do{
for(int i=0;i<4;i++)
data[i]=mySerial.read();
}while(mySerial.read()==0xff);
mySerial.flush();
if(data[0]==0xff)
int sum;
sum = 0;
sum=(data[0]+data[1]+data[2])&0x00FF;
if(sum==data[3])
rawValue=(data[1]<<8)+data[2];
if(rawValue>280)
sensorValue = (rawValue/10);
sensorValue = 0.0;
memset(databufSensor, 0, sizeof(databufSensor));
dtostrf(sensorValue,min_width,num_digits_after_decimal,databufSensor);
int batValue = analogRead(A2);
float batvolt= batValue * (5.0 / 1024.0);
memset(databufBatvolt, 0, sizeof(databufBatvolt));
dtostrf(batvolt,min_width,num_digits_after_decimal,databufBatvolt);
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (rf95.waitAvailableTimeout(100))
if (rf95.recv(buf, &len))
int dataLength;
String Request = (char*)buf;
if (Request == "C1") {
String data = String(databufSensor)+';'+String(databufBatvolt);
int dataLength = data.length();dataLength++;
uint8_t total[dataLength];
memset(total, 0, sizeof(total));
data.toCharArray(reinterpret_cast<char *>(total),dataLength);
rf95.send(total, dataLength);
rf95.waitPacketSent();
Request = "";
Source Server
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
RH_RF95 rf95(10,2);
unsigned long millisBefore;
String voltage;
String sensorPosition;
int turn = 1;
String recievedData;
float batvolt;
float percentage;
// On an arduino UNO: A4(SDA), A5(SCL)
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET 5 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
while (!Serial); // Wait for serial port to be available
if (!rf95.init())
//SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));}
Communication();
void Communication()
if (millis() - millisBefore < 500)
if (turn == 1)
display.clearDisplay();
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(0,0);
sendRequest("C1");
recievedData = waitForAnswer();
int posDelimiter = recievedData.indexOf(';');
sensorPosition = recievedData.substring(0,posDelimiter);
voltage = recievedData.substring(posDelimiter + 1 ,recievedData.length());
batvolt = voltage.toFloat();
percentage = ((batvolt-3)/0.7)*100;
display.println(" "+voltage + "V " + percentage + "%");
display.setTextSize(2);// Draw 2X-scale text
display.println(" "+sensorPosition + "cm");
display.display();
turn = 2;
}else if ((millis() - millisBefore > 500) && (millis() - millisBefore < 1000)) {
if (turn == 2)
millisBefore = millis();
turn = 1;
void sendRequest(String request)
unsigned int dataLength = request.length(); dataLength ++;
request.toCharArray(reinterpret_cast<char *>(total), dataLength);
String waitForAnswer() {
//Now wait for a reply
memset(buf, 0, sizeof(buf));
if (rf95.waitAvailableTimeout(500))
return (char*)buf;
Serial.println("recv failed");
