Hello, I'm trying to setup the Enc28j60 Ethernet module with the Arduino uno. I followed This Page which is on the Arduino link to the "T" in wiring as well as library and Sketch. But for some odd reason. I can not get the Ethernet to work. I'm also using the Arduino IDE version 1.8.16. I'm not sure what else to do I looked and looked all over But so far no fix. Can someone please help me out to figure this problem on why I can not get it to work.
I'm running the Be Back soon Example from the Library I'm posting below. Only thing I have changed was the Ip address to 244 from 200. Everything else remains the same. Also there is no error in compiling and upload.
// Present a "Will be back soon web page", as stand-in webserver.
// 2011-01-30 <jc@wippler.nl>
// License: GPLv2
#include <EtherCard.h>
#define STATIC 0 // set to 1 to disable DHCP (adjust myip/gwip values below)
#if STATIC
// ethernet interface ip address
static byte myip[] = { 192,168,1,244 };
// gateway ip address
static byte gwip[] = { 192,168,1,1 };
#endif
// ethernet mac address - must be unique on your network
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
byte Ethernet::buffer[500]; // tcp/ip send and receive buffer
const char page[] PROGMEM =
"HTTP/1.0 503 Service Unavailable\r\n"
"Content-Type: text/html\r\n"
"Retry-After: 600\r\n"
"\r\n"
"<html>"
"<head><title>"
"Service Temporarily Unavailable"
"</title></head>"
"<body>"
"<h3>This service is currently unavailable</h3>"
"<p><em>"
"The main server is currently off-line.<br />"
"Please try again later."
"</em></p>"
"</body>"
"</html>"
void setup(){
Serial.begin(57600);
Serial.println("\n[backSoon]");
// Change 'SS' to your Slave Select pin, if you arn't using the default pin
if (ether.begin(sizeof Ethernet::buffer, mymac, SS) == 0)
Serial.println( "Failed to access Ethernet controller");
#if STATIC
ether.staticSetup(myip, gwip);
#else
if (!ether.dhcpSetup())
Serial.println("DHCP failed");
#endif
ether.printIp("IP: ", ether.myip);
ether.printIp("GW: ", ether.gwip);
ether.printIp("DNS: ", ether.dnsip);
void loop(){
// wait for an incoming TCP packet, but ignore its contents
if (ether.packetLoop(ether.packetReceive())) {
memcpy_P(ether.tcpOffset(), page, sizeof page);
ether.httpServerReply(sizeof page - 1);
Edit: I did put the ethernet wire into my laptop and Got a Ip address and I got onto the internet with no problem. So I know the connection ethernet wire works.
Joseph
