how to check if my RAM ran out ?
I assume you have taken the advice on the code , so that should be fixed ?
When you upload code , in orange, it will say at the bottom memory usage .
Check all you connections ( wobble them) replace any loose leads .
it say 36 % is used when i upload the code in arduino ide.
Does the code above looks heavy for ram ?
Where you probably suspect why the arduino uno freeze after some days of work ?
I suspect a bad connection .
It might be worth re wiring and carefully checking all connections .
Failing that , build up slowly - just run the display for a couple of days , then add say humidity to try and find when the problem occurs .
A photo of the installation would help here.
You have a relay in there that you forgot to mention - if that is powered via a pin on the Arduino - then that is an issue .
The relay should have a fly back diode across the coil .
Iām sorry but the wiring a complete mess and likely to be a big part of your issue .
Iād suggest you lay it out in a logical fashion , all mounted on some sort of board.
Keep the mains connections well away from the board to prevent any interference from the switching .
Yes the relay has a flashback diode (led) parallel with the coin, and the relay is controled by pin 6.
You canāt drive a relay from an output pin, what coin ? - you have stuff here that you didnāt mention which wastes peopleās time . A led is not a fly back diode . There is enough in this thread for you to study and correct .
Have a look at the layout below , which is logical and neat - you should aim for this . You could easily have a wire fall off and touch a mains connection on your ā layout ā The relay should be boxed with not access to live terminals .
Example
The diode should be across the coil not in series with it .
You canāt power the relay from the Arduino 5v pin .
You have no resistor in series with the led , the led performs no function in the way you have it
My final word is to start over , check and test each stage .package the relay and do some tidy wiring .
I canāt offer any more , sorry .
THANK YOU hummy for your suggestions.
The relay is 5v and consume 50mA that is not much for arduino, i have check that amperage with multimeter.
You are correct !!, i will replace led diode to diode 1N4007 in the scheme above.
You probably should get a transistor to drive that relay.
You will need a better power supply.
He has ! The relay coil is powered from the 5v pin.
As an aside for the OP I spent an hour today trying to get a GPS to work - bad DuPont lead !!
Ohā¦.. Was still looking at the schematic.
Sorry.
I make some changes as hammy suggested.
Hope that i will have no problem, otherwise i will provide the full schematic with every detail.
Hope that it will work.
THANK YOU ALL FOR YOUR SUGGESTIONS
The problem as I see it is the OP does not have the tools or skill set to draw a schematic (the language of electronics). KiCad, a great program if free for the downloading. It will take some time to learn to use it but once you do!!! There are a lot of tutorials online to help with it.
I expect when an annotated schematic is posted the problem will be found in short order.
