Arduino Uno Locking up
I prefer a state machine approach. Like this:
//Import Libraries
#include <ezButton.h>
// Map constant names to IO pins
const byte Furnace_Rly = 13;
const byte LightOn_Rly = 12;
const byte LightOff_Rly = 11;
const byte Door1_Rly = 10;
const byte Door2_Rly = 9;
const byte Door3_Rly = 8;
const byte Door4_Rly = 7;
const unsigned long ResponseTime = 20UL*60UL* 1000UL;
const unsigned long TimeDoorsOpen = 900UL*1000UL; // This is the time in milliseconds that the doors will remain open
unsigned long SystemActivatedTime;
unsigned long DoorOpenTime;
// Define EZButton
ezButton Door1_Sen(6);
ezButton Door2_Sen(5);
ezButton Door3_Sen(4);
ezButton Door4_Sen(3);
ezButton Tone_Sen(2);
ezButton Motion_Sen(1);
// Create System Variables
int Door1_State; // State of the door sensor
int Door2_State; // State of the door sensor
int Door3_State; // State of the door sensor
int Door4_State; // State of the door sensor
  // Setup EZButton
  Door1_Sen.setDebounceTime(250); // set debounce time to 250 milliseconds
  Door2_Sen.setDebounceTime(250); // set debounce time to 250 milliseconds
  Door3_Sen.setDebounceTime(250); // set debounce time to 250 milliseconds
  Door4_Sen.setDebounceTime(250); // set debounce time to 250 milliseconds
  Tone_Sen.setDebounceTime(250); // set debounce time to 250 milliseconds
  Motion_Sen.setDebounceTime(250); // set debounce time to 250 milliseconds
  // Setup IO pins
  pinMode(Furnace_Rly, OUTPUT); // Relay to turn the furnace off
  pinMode(LightOn_Rly, OUTPUT); // Override Light On Control Relay
  pinMode(LightOff_Rly, OUTPUT); // Ovveride Light Off Control Relay
  pinMode(Door1_Rly, OUTPUT); // Bay 1 Door Relay
  pinMode(Door2_Rly, OUTPUT); // Bay 2 Door Relay
  pinMode(Door3_Rly, OUTPUT); // Bay 3 Door Relay
  pinMode(Door4_Rly, OUTPUT); // Bay 4 Door Relay
enum States {IDLE,WaitingForMotion,ALARM,OpenAllDoors,WaitingForClose,CloseAllDoors};
States State;
HandleButtons();
switch(State)
  case IDLE:
    if (Tone_Sen.isReleased())
      SystemActivatedTime=millis();
      digitalWrite(LightOn_Rly, HIGH); // Turn Lights On
      State=WaitingForMotion;
  case WaitingForMotion:
    if (Motion_Sen.isReleased())
      State=OpenAllDoors;
    if(millis()-SystemActivatedTime>ResponseTime)
      State=IDLE;
  case OpenAllDoors:
    digitalWrite(Furnace_Rly, HIGH); //Furnace off
    OpenTheDoors();
    DoorOpenTime=millis();
    State=WaitingForClose;
  case WaitingForClose:
    if(millis()-DoorOpenTime > TimeDoorsOpen)
      State=CloseAllDoors;
  case CloseAllDoors:
    FlashLights();
    CloseTheDoors();
    digitalWrite(Furnace_Rly, LOW);  //Furnace back on
    State=IDLE;
  default:
void HandleButtons()
// EZButton
Door1_Sen.loop();
Door2_Sen.loop();
Door3_Sen.loop();
Door4_Sen.loop();
Tone_Sen.loop();
Motion_Sen.loop();
void OpenTheDoors()
// System Activation by Tone, don't reactivate within 15 seconds
// Trigger Doors open when motion is sensed within the response time
// Read Door Sensors
Door1_State = Door1_Sen.getState();
Door2_State = Door2_Sen.getState();
Door3_State = Door3_Sen.getState();
Door4_State = Door4_Sen.getState();
if (Door1_State == LOW)   // Sense if Door 1 is Open
  digitalWrite(Door1_Rly, HIGH); // Open Door 1 if not open
if (Door2_State == LOW)   // Sense if Door 2 is Open
  digitalWrite(Door2_Rly, HIGH); // Open Door 2 if not open
if (Door3_State == LOW)   // Sense if Door 3 is Open
  digitalWrite(Door3_Rly, HIGH); // Open Door 3 if not open
if (Door4_State == LOW)   // Sense if Door 4 is Open
  digitalWrite(Door4_Rly, HIGH); // Open Door 4 if not open
delay(750); // Wait for 750 millisecond(s)
digitalWrite(Door1_Rly, LOW); // Close door switch after a delay
digitalWrite(Door2_Rly, LOW); // Close door switch after a delay
digitalWrite(Door3_Rly, LOW); // Close door switch after a delay
digitalWrite(Door4_Rly, LOW); // Close door switch after a delay
void FlashLights()
for(int lp=0;lp < 10;lp++)
  digitalWrite(LightOff_Rly, HIGH); // Switch the lights off override on
  delay(900);
  digitalWrite(LightOff_Rly, LOW); // Switch the lights off override off
  delay(900);
void CloseTheDoors()
    if (Door1_State == HIGH)   // Sense if Door 1 is Closed
      digitalWrite(Door1_Rly, HIGH); // Close Door 1 if not Closed
    if (Door2_State == HIGH)   // Sense if Door 2 is Closed
      digitalWrite(Door2_Rly, HIGH); // Close Door 2 if not Closed
    if (Door3_State == HIGH)   // Sense if Door 3 is Closed
      digitalWrite(Door3_Rly, HIGH); // Close Door 3 if not Closed
    if (Door4_State == HIGH)   // Sense if Door 4 is Closed
      digitalWrite(Door4_Rly, HIGH); // Close Door 4 if not Closed
    delay(750);
UKHeliBob:
Good news that you got it working
I see multiple variables in your code with numbers in their names. This is very often an indication that the code could be shortened by the use of arrays, but I have not looked in detail
I suppose that will be the next thing I learn. This project has been a learning experience every step of the way as it really is my first arduino project.
wildbill:
//Import Libraries
const unsigned long ResponseTime = 20UL60UL 1000UL;
// Define EZButton
 // Setup EZButton
 // Setup IO pins
States State;
HandleButtons();
switch(State)
 case IDLE:
     State=OpenAllDoors;
     State=IDLE;
 case OpenAllDoors:
   OpenTheDoors();
 case CloseAllDoors:
   FlashLights();
   CloseTheDoors();
   State=IDLE;
 default:
// EZButton
Door1_Sen.loop();
Door2_Sen.loop();
Door3_Sen.loop();
Door4_Sen.loop();
Tone_Sen.loop();
Motion_Sen.loop();
void OpenTheDoors()
void FlashLights()
 delay(900);
 delay(900);
   delay(750);
There are a few functions missing there compared to what I posted. Unless I am mistaken, your code is blocking quite a bit. During the whole flash sequence before closing the doors, the delays would cause the input from sensors to be ignored (such as a new activation of tones). Also, the furnace is meant to turn off and the lights turn on even if the doors are opened manually.
Fair enough. I suspected that it would not be quite right. Fixable of course. But it does illustrate the state machine method I think.
wildbill:
I appreciate the effort, that likely didn't take a small amount of time for you to put together.
