Good morning,
This is my first post with regards to the Arduino project.
I am very inexperienced with regards to the Arduino processor & system.
However I do see the value & the benefits that the Arduino processor can unleash for some one in my position.
Is it possible to read & to learn exactly what all the pins do on the Arduino Uno board?
The kit that I have purchased does not give me the information that I am seeking.
May be the designers of the board have made this information available, but I for one have not been able to locate it.
Some pins are pretty obvious:
Reset: low reset the '328P microcontroller (uC)
5V: generally 5V output to other devices, limited current capability
3.3V: generally 5V output to other devices, limited current capability
Vin: generally an output from the barrel jack connector. Can be an input, bypassing the reverse polarity protection diode.
Analog 0-5: Analog input pins, can also be used as digital IO.
IO pins: SCL, SDC: I2C lines to connect to other I2C devices. They also connect to A4/A5.
D0-D13: Digital IO pins. Most have multiple capability. 6 specifically are hardware PWM out capable, using analogWrite( ) command; see ~ marking. 2 are specifically hardware Serial IO lines and also connect to the USB/Serial adapter chip; D0/D1. 3 are specifically SPI interface lines; D11/D12/D13.
More about the capabilities of each pin can be read in the '328P datasheet:
Download the .PDF schematic from the Products page to see which pin connects to the which IO pin.
dafyddclaud:
Good morning,
Can any one help?
Thank you
DAFYDD CLAUD MIGGIANO.
Good morning,
If one was to read Sig Massimo Banzi's book ''second edition'' the pin lay out is referred & described in his book.
I have downloaded the book for now but I have also bought a copy on line.
need I say, nothing like real paper to play with, even in this electronic & digital world.
What may be of interest to some people is a section in the web site that does describe the various pins & functions
of each Arduino board, it would save people like me a lot of time.
dafyddclaud:
