Hi everyone,
I'm currently working on a quadrotor project using Arduino UNO R3 board as a flight controller, to do so, I'm using a 11.1V 3S LiPo battery for my drone and I'd like to use a LM2596 step down module to supply my board via this battery, so my question is : Should I connect the LM2596 output to V in port or the DC Power Jack/USB port?
If you can use the DC Power Jack you don;t need the LM2596, the jack already has one.
Can you post an annotated schematic showing what you are going to connect to the UNO and to which pins. Show all external hardware and power sources.
Set the buck to 9V and connect to either Vin or the barrel jack.
What is the step down module's output voltage?
Is it possible to connect the DC power jack to the step down output by regulating the output at 5V?
Thanks, are both case safe for the Arduino board? ![]()
Normally, the output is adjustable (from 1.25V to 35V) but I just want to know which voltage value is safe for the arduino board and to which port shoould I connect the step down's output
I would just connect the 11.1V to the jack, here is the spec
Yes
