Arduino Uno Q Synth idea
Hello everyone who reads this post I want to create a Synthesizer instrument using the Arduino Uno Q. Is it possible to do this using the components from the Arduino Make Your UNO Kit (basically using everything besides the provided uno from this kit) So I want to substitute the board with the UNO Q . The reason why I want to do this is because I want to create a more complex Synth that uses AI to generate sounds. I have not seen any music related projects in relation with the UNO Q does anyone have experience with experimenting using it to create audio.
How many years of experience do you have with advanced hardware, similarly experience with code?
little to none I would most likely try to follow the directions from the Make your UNO kit. The only type of experience I have had with audio related arduino projects is making something like this
No the UnoQ is much different..
The audio is handled in linux using the MPU..
So you would need a USB hub and USB audio device..
Then you could do buttons like in the vid you posted..
Also remember the MCU on the Q is 3.3v not 5v like the uno in the kit, so all the pieces are probably wrong too..
Here's the theremin example never played with it but should give you some ideas..
good luck.. ~q
Thank you for the information. I still want to use the Q to make a synth instrument. I know its still a new board so their arent any tutorials and guides showing if people have done it.
Correct. The closest you will come is the link that @qubits-us gave you.
What does that actually mean? AI will not generate sounds for you.
I suspect that you know nothing about music or synthesising sound, so you have a very long way to go before you can get into the AI field. Also can you actually write music?
You are better off using a commercial AI system that does know these things.
The thing is that an Arduino Q is a 3V3 device and any attempt to use voltages in excess of this, (that is your Arduino Make kit), will result in damage to the Arduino Q.
Ok that is technically not what I meant All I want to do is produce audio similar to a video like this Using the Arduino Q board.
well you actually said
So what "technically" did you mean?
So this video is actually producing very poor sounds and you want to reproduce this using an Arduino Q!
Well you can't because of the voltages I told you about. This makes the circuit shown in this video and the software driving it not work.
Unless of course if you don't mind blowing up your expensive Arduino Q. I repeat again the Arduino Q is not a 5V tolerant device.
As was explained, the shield from this kit is designed for use with a board that supports up to 5 V input to the analog pins. Although the UNO Q does have 5 V tolerant digital pins, the maximum input voltage for the analog pins is 3.3 V. For this reason, the shield from the "Make your UNO Kit" could only be used with the UNO Q after modification of the circuit.
The necessary modification is to connect the "3.3V" pin on the UNO Q to the "5V" pin on the shield, instead of the usual arrangement where that pin on the shield is connected to the 5 V pin on the Arduino board. You could accomplish this by bending the male "5V" and "IOREF" pins on the bottom of the shield outward before plugging the shield into the UNO Q, so that the pins do not insert into the female header on the UNO Q and thus do not make an electrical connection. You would then solder a wire jumper between the "3.3V" pin and "5V" pin on the shield.
:warning: You should be aware that bending header pins causes the metal to weaken. If bent repeatedly, the pins may eventually break off, making it so that you would not be able to go back to using the shield as intended with a 5 V board like the DIY UNO from the kit. So this is very much an "at your own risk" sort of endeavor.
Something you might find interesting is the "Sound Generator" Brick that was recently created by the Arduino Developers. This hasn't actually been released yet, so you won't find it in your Arduino App Lab today, but it should be in the next release.
https://github.com/arduino/arduino-app-cli/blob/main/debian/arduino-app-cli/var/lib/arduino-app-cli/assets/0.8.0/api-docs/arduino/app_bricks/sound_generator/API.md#sound_generator-api-reference
There is an example demonstrating its usage here:
https://github.com/arduino/app-bricks-examples/tree/main/examples/music-composer#music-composer
You operate UNO Q in Single Board Computer Mode (Fig-1) using 1-to-11 dongle. Use Audio Generator Unit (Fig-2) of MPU to generate audio sound/music and route it to outside speaker from Audio Outlet of the dongle (Fig-2).
Figure-1:
Figure-2:
