Hello,
I'm having a problem with read SD card.
Platform Arduino Uno + SD module
13 - SCK
12 - MISO
11 - MOSI
10 - CS
+5V
GND
Card - SD 1GB Kingston, Fat16.
Code from EXAMPLES/ReadWrite library SdFat.
#define SD_CS_PIN SS
#include <SPI.h>
//#include <SD.h>
#include <SdFat.h>
SdFat SD;
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(SD_CS_PIN)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3.");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
// nothing happens after setup
After compilation message from Arduino Serial Monitor:
Initializing SD card...initialization done.
Writing to test.txt...done.
File is created OK, there is inside "1,2,3".
I cannot open again this file.
I have tried change 5V to 3.3V, change CS pin to 4, different SD card, but problem is still the same.
Can anyone help?
Cheers.
