i would like to power my Arduino uno with a solar power bank using a boost DC-DC converter to reach the 7V input needed.
Now, suppose the solar power bank has no energy at the moment and i have already linked it to arduino.
What would happens if i put it at the sun light? I mean, will the arduino works properly or will it consume all the energy as it starts and then it will try to restart everytime it has some energy? (finishing the energy again)
If the second option holds, is there a way to say: "ok, now wait until you have enough energy to do some operations and then do it" ? (Maybe with some component between the power bank and arduino)
Using more solar power banks in parallel could help?
I hope you can help me with this
Thanks and have a good week-end
litya:
Arduino specifics say it accept between 7V and 12V to the power jack, or 5V through usb.
You can connect a "solar + battery bank" directly to the Arduino with a USB lead.
A solar "charger" (without inbuild battery) won't work.
Battery banks do have a boost converter to step-up from the LiPo battery voltage to 5volt USB socket.
Expect the amp-hours to be ~2/3 of the rating because of that.
And don't trust the factory rating on the pack.
Leo..
thank you for your help, it is now clear to me that i can remove the boost converter
Now i have a last question; the charge regulator works when i have a solar panel and a battery that are not in the same device so that you can connect their wires in the charge controller (it has 6 entries for battery, load and charge).
Is there a similar device (similar to charge controller) that works with a device where battery and charge are in the same device (as the power bank do)?
I need the function that when the battery has low charge the load get disconnected until the battery get enough charge (maybe exists a device with this function but i don't know his name :p).
I bought one of those and they are seriously nowhere near the "rated" capacity they advertise.
I pulled it apart and it seems they happily add a 0 or maybe two 0s to the capacity rating on the advert...
They also take a long time to charge in good sun, 40 hours on that one apparently...so it will drain quickly depending on what you are running.
Assuming you need 400mA at 5V = 2.5W ish. Even with full sun, that solar panel with 100% efficient components does not look like it could even power the arduino in the first place with no charge.
I made my own power station for my greenhouse using some deep-cycle lead acid batteries, a solar control charger (Solar Charge Controller) and a decent 80W solar panel.
You can of course try scale this down...but if you want to be drawing over an Amp 24/7 at 5V...then yeah...you need something a bit more hefty.
