Arduino Uno with one analog and one digital servo
Hi everyone I am just learning arduino. My code is very simple, I am moving a micro servo to 10 degrees when I press button 1 and moving to 60 degress when I press button 2. The code works great for the analog servo, but if I keep the code identical and just unplug the analog and plug in the digital the digital servo just kind of hums and doesn't respond. Per my research I thought that I could address analog and digital servos the same way, but am I missing something? This is all on pin 9 and I am not debouncing the switch in software.
Guess we will never know.
Unless of course, you read the instructions and post your code.
p7aymak3r:
That's my understanding also but this....
.... indicates that there might be a power problem. Perhaps it has nothing to do with being a digital servo, but with it requiring more power?
Thanks guys, but I did read the instructions, I'm not sure what I did wrong in that post?
I tried it with my own code and also with this code I found online and get the same behavior, analog works fine, digital just hums and kind of stutters
#include <Servo.h>
Servo rightleft;
int right = 7;
int left = 8;
int right_state;
int left_state;
int servo_val;
  pinMode(right, INPUT);
  pinMode(left, INPUT);
  rightleft.attach(6);
  servo_val = rightleft.read();
  right_state = digitalRead(right);
  left_state = digitalRead(left);
  if(right_state == HIGH)
    rightleft.write(servo_val - 1);
    delay(14);
    Serial.println("Right HIGH");
  if(left_state == HIGH)
  rightleft.write(servo_val + 1);
  delay(14);
  Serial.println("Left HIGH");
The power consumption thing might be it. I'm using a lipo, but this website said it might not be enough. Maybe you need more power and separate motor controller for digital servos?
https://www.servocity.com/html/digital_servo_faq.html
Or maybe it's a bigger servo, and just draws more current- you didn't say.
Nor have you shown us your circuit. I hope you're not powering (as distinct from controlling) either of them from the Arduino....
