Arduino Uno with Texas Instrument AMC7834 via SPI
Hi all, I am pretty newby in Arduino but for an RF project I would like to interface the Arduino Uno to the https://www.ti.com/product/AMC7834. I would like to start reading Device ID only but the fact that I have to read 24 bits (3 bytes) is confusing me. Here below the code, if someone can help.
#include <SPI.h>
//pin 13 SCLK
//pin 12 MISO on Arduino side, SDO on TXS
//pin 11 MOSI on Arduino side, SDI on TXS
const int csPin = 10;  // Pin di selezione dello slave (CS)
  pinMode(csPin, OUTPUT);
  digitalWrite(csPin, HIGH);  // Deseleziona l'SPI slave
  SPI.begin();
  SPI.setClockDivider(SPI_CLOCK_DIV2); // Imposta la velocità SPI
  SPI.setDataMode(SPI_MODE0); // Imposta il modo di SPI
  byte devID = readdevID();
  Serial.print("Device ID: ");
  Serial.println(devID);
byte readdevID() {
  digitalWrite(csPin, LOW);
  // First byte is to read the register (0x80 per leggere)
  byte command = 0x80 | 0x04;
  SPI.transfer(command);
  // Leggi i dati (2 byte)
  byte msb = SPI.transfer(0x000); // Ottieni il byte più significativo
  byte lsb = SPI.transfer(0x000); // Ottieni il byte a meno significativo
  byte devID = msb | lsb;
  return devID;
The AMC7834 datasheet specifies that the device ID is a 24-bit register, meaning it consists of three bytes. Your code needs some modification in this regard:
#include <SPI.h>
// Pin connections to the SPI interface
const int csPin = 10;  // Chip Select (CS) pin
  digitalWrite(csPin, HIGH);  // Deselect the SPI slave
  SPI.begin();
  SPI.setClockDivider(SPI_CLOCK_DIV2); // Set SPI speed
  SPI.setDataMode(SPI_MODE0); // Set SPI mode
  // Read and print the device ID
  uint32_t devID = readDeviceID();
  Serial.print("Device ID: 0x");
  Serial.println(devID, HEX);  // Print in hexadecimal format
uint32_t readDeviceID() {
  digitalWrite(csPin, LOW);  // Select the SPI slave
  // Send command to read the device ID register
  byte command = 0x80 | 0x04; // Assuming 0x04 is the correct register address
  // Read the three bytes from the device ID register
  byte msb = SPI.transfer(0x00);    // Most significant byte
  byte mid = SPI.transfer(0x00);    // Middle byte
  byte lsb = SPI.transfer(0x00);    // Least significant byte
  // Combine the three bytes into a single 24-bit value
  uint32_t devID = ((uint32_t)msb << 16) | ((uint32_t)mid << 8) | lsb;
  return devID;
@stem88
Your main problem is incompatible logic levels. The 7834 I/O are 3.3V and the Uno is 5V.
So first thing is to buy a level translator.
No, the ID is only 16 bits. All registers are only 16 bits (2 bytes)
Don't use setClockDiviseo or setDataMode
Use instead
SPI.beginTransaction(SPISettings(2000000, MSBFIRST, SPI_MODE0))
https://docs.arduino.cc/language-reference/en/functions/communication/SPI/SPISettings/
Also add a 10us delay after you bring CS low and before you bring it high
You are misinterpreting. Transfers are 24 bits composed of an 8-bit register address and a 16-bit register value.
