Arduino Uno with water level control and flow meter, program resets itself
I am a beginner with Arduino. I do have a good understanding of how it works. As well I 'm not much of a code writer but I can read and understand a good portion of it.
My project is for a vertical hydroponics garden. My design does not allow for a large reservoir so I need to activly control water level. As well I need to be able to drip fertilizer when the pump is running so I need to incorporate a flow meter. I'm using an ultra sonic sensor for water level control and some modified code I found online. The flow meter is a Hall effect sensor.
My issue is that when the pump is activated by way of a relay the flow meter will measure the amount of water and I will be able to adjust the drip. I can verify the code and upload it to the Arduino Uno. However, when the flow meter is activated it reset the program. I have been able to run both programs separately but when I try to combine them I have my issue. I don't really know how to combine the two programs to have them work independently. So I think this is my issue. Any help or direction to solve my problem would be greatly appreciated .
// include the library code:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x27 for a 16 chars and 2 line display
#include <NewPing.h> // Include  library used for measuring the distance using HC-SR 06 sonar sensor
#define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN   7  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 500 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
#define MOTORPIN 8 // Arduino pin tied to Relaypin of the Relay Circuit
byte statusLed    = 13;
int sensorInterrupt = 0;  // 0 = digital pin 2
int sensorPin       = 2;
float calibrationFactor = 7.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
float val;
#include <EEPROM.h>
int addr = 0;
int addr2 = 1;
int flag;
byte readval;
#define buttonPin 10
int buttonState = 0;      // variable for reading the pushbutton status
float TankHeight, WaterLevelMAX, GapbwSonar, SonarReading, ActualReading,  Temp;
int percentage;
 lcd.init();                      // initialize the lcd
 // Print a message to the LCD.
 lcd.backlight();
 lcd.begin(20, 4); // set up the LCD's number of columns and rows:
 pinMode(MOTORPIN,OUTPUT);// Relay pin as output pin
// pinMode(EXTRELAYPIN,OUTPUT);// External Relay pin as output pin
 digitalWrite(MOTORPIN,HIGH); //Turn off the relay
 lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Starting ARDUINO, ");
  lcd.setCursor(0,1);
  lcd.print("Press SCAN Button to");
  lcd.setCursor(0,2);
  lcd.print("Change Tank Height  ");
  lcd.setCursor(0,3);
  lcd.print("If Required  ");
  delay(2000);
// delay(1000);
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("Confirm Tank Must be");
 lcd.setCursor(0,1);
 lcd.print("Empty to Set Tank   ");
 lcd.setCursor(0,2);
 lcd.print("Height using Sonar  ");
 delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Now Scan to Change  ");
lcd.setCursor(0,1);
lcd.print("Tank Height to New  ");
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Long Press Button...");
 for (int i=0; i<=5; i++)
 lcd.setCursor(0,1);
 lcd.print("  Hold :  ");
 lcd.print(5-i);
 lcd.print(" Seconds ");
 buttonState = digitalRead(buttonPin);
 if (buttonState == HIGH)
 TankHeight =sonar.ping_cm();
 EEPROM.write(addr, TankHeight);
 {TankHeight= EEPROM.read(addr);
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("Tank New Height Set@");
 lcd.setCursor(0,1);
 lcd.print(" ");
 lcd.print(TankHeight);
 lcd.print("cm ");
 delay(2000);
 lcd.clear();
 lcd.setCursor(0,2);
 lcd.print("TANK HEIGHT: ");
 //lcd.print("cm ");
 lcd.setCursor(12,2);
 lcd.print("cm ");
 WaterLevelMAX=0.9*TankHeight;  // 10CM GAP BETWEEN MAX WATER LEVEL TO SONAR FIX
// WaterLevelMAX= 5-TankHeight;
 GapbwSonar=TankHeight-WaterLevelMAX;}
// Set up the status LED line as an output
 pinMode(statusLed, OUTPUT);
 digitalWrite(statusLed, HIGH);
 pinMode(sensorPin, INPUT);
 digitalWrite(sensorPin, HIGH);
 pulseCount        = 0;
 flowRate          = 0.0;
 flowMilliLitres   = 0;
 totalMilliLitres  = 0;
 oldTime           = 0;
 // The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
 // Configured to trigger on a FALLING state change (transition from HIGH
 // state to LOW state)
 //  main code to run repeatedly:
 delay(1000); // Wait 100ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
 SonarReading=sonar.ping_cm();
 //Serial.println(DRYsensorValue);
 Temp= SonarReading-GapbwSonar;
 ActualReading= WaterLevelMAX-Temp;
 percentage=(ActualReading/WaterLevelMAX*100);
 Serial.println(percentage);
 //Serial.println(TankHeight);
 lcd.setCursor(0,0);
 lcd.print("WATER LEVEL:");
 lcd.print(percentage);
 lcd.print("%  ");
 if(percentage<=40)
 lcd.setCursor(0,1);
 lcd.print("PUMP STATUS: RUNNING");
 digitalWrite(MOTORPIN,LOW);
flag=1;
 EEPROM.write(addr2, flag);
 flag= EEPROM.read(addr2);
//  ZeroPercentage();
  ((millis() - oldTime) > 100);    // Only process counters once per second
    detachInterrupt(sensorInterrupt);
   // Because this loop may not complete in exactly 1 second intervals we calculate
   // the number of milliseconds that have passed since the last execution and use
   // that to scale the output. We also apply the calibrationFactor to scale the output
   // based on the number of pulses per second per units of measure (litres/minute in
   // this case) coming from the sensor.
   flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
   // Note the time this processing pass was executed. Note that because we've
   // disabled interrupts the millis() function won't actually be incrementing right
   // at this point, but it will still return the value it was set to just before
   // interrupts went away.
   oldTime = millis();
   // Divide the flow rate in litres/minute by 60 to determine how many litres have
   // passed through the sensor in this 1 second interval, then multiply by 1000 to
   // convert to millilitres.
   flowMilliLitres = (flowRate / 60) * 1000;
   // Add the millilitres passed in this second to the cumulative total
   totalMilliLitres += flowMilliLitres;
   unsigned int frac;
    // Reset the pulse counter so we can start incrementing again
   pulseCount = 0;
   // Enable the interrupt again now that we've finished sending output
   attachInterrupt(sensorInterrupt, pulseCount, FALLING);
 if(percentage>60 && percentage<=100)
 delay(15000);
 lcd.setCursor(0,1);
 lcd.print("PUMP STATUS: OFF    ");
 lcd.setCursor(0,0);
 lcd.print("Water Level:");
                                  // This line is wrong . Should print actual fix it
 lcd.print("%  ");
// digitalWrite(EXTRELAYPIN,HIGH);
 flag=0;
//  HundredPercentage();
 if(flag==1)
 //  lcd.clear();
 lcd.setCursor(0,3);
 lcd.print(" Flow Rate");
 lcd.setCursor(1, 3);
 lcd.print(flowRate);
 lcd.setCursor(6, 3);
 lcd.print("L/Min");
 digitalWrite(MOTORPIN, LOW);
// digitalWrite(EXTRELAYPIN, HIGH);
 delay(300);
 delay(300);
 else if(flag==0)
 lcd.setCursor(0,3);
 lcd.print("SUMP: NOWATER/CHECK");
(Code tags and extra blank lines deleted by Moderator. Next post, use the </> button on the menu and paste your code in the box that opens. Be sure to use CTRL-T in the IDE before pasting it in.)
Could you post your Schematic showing all power and ground connections for all power supplies etc. This could be an electronic problem so I want to check the electronics before I consider going through the code.
I don't have a schematic, but I could easy make one. What software do you recommend for doing this?
pnorsworthy:
Hand drawn is fine if clear and legible. If you want software assistance there's Express SCH among others. (Not a recommendation).
Express SCH is great for projects like this. Easy to make symbols for your components if you do not see a part you need.
I use windows XP Paint. To be honest i glanced at your code, but i do not have any overview of how it is actually structured. Basically all is either in setup() or in loop() (which is huge) Please format your code using ctrl-T and i think you should really put some sections in functions. It will create more overview and will be more explanatory than a few lines of comments.
I'm still working on the schematic, but in the meantime I have got my code to run and work properly. Simple mistakes of a beginner. No on to the next step of my project. I will try to finish the schematic and get it upload incase anyone has any advice for me.
