I am new to Arduino. I've installed the Arduino IDE 1.0 on a MacOSX platform and have been checking out Mikal Hart's TinyGPS package.
http://arduiniana.org/libraries/tinygps/
http://arduiniana.org/TinyGPS/TinyGPS10.zip
However I'm encountering a compile error with one of the example sketches included with the package - "static_test.pde" - which I am unable to solve.
#include <TinyGPS.h>
#include <avr/pgmspace.h>
/* This sample code demonstrates the basic use of a TinyGPS object.
Typically, you would feed it characters from a serial GPS device, but
this example uses static strings for simplicity.
prog_char str1[] PROGMEM = "$GPRMC,201547.000,A,3014.5527,N,09749.5808,W,0.24,163.05,040109,,*1A";
prog_char str2[] PROGMEM = "$GPGGA,201548.000,3014.5529,N,09749.5808,W,1,07,1.5,225.6,M,-22.5,M,18.8,0000*78";
prog_char str3[] PROGMEM = "$GPRMC,201548.000,A,3014.5529,N,09749.5808,W,0.17,53.25,040109,,*2B";
prog_char str4[] PROGMEM = "$GPGGA,201549.000,3014.5533,N,09749.5812,W,1,07,1.5,223.5,M,-22.5,M,18.8,0000*7C";
prog_char *teststrs[4] = {str1, str2, str3, str4};
void sendstring(TinyGPS &gps, const PROGMEM char *str);
void gpsdump(TinyGPS &gps);
Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("by Mikal Hart");
Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
for (int i=0; i<4; ++i)
TinyGPS test_gps;
Serial.print("Test string #"); Serial.println(i+1);
Serial.println("--------------");
sendstring(test_gps, teststrs[i]);
gpsdump(test_gps);
void printFloat(double number, int digits=5)
// Handle negative numbers
if (number < 0.0)
Serial.print('-');
number = -number;
// Round correctly so that print(1.999, 2) prints as "2.00"
double rounding = 0.5;
for (uint8_t i=0; i<digits; ++i)
rounding /= 10.0;
number += rounding;
// Extract the integer part of the number and print it
unsigned long int_part = (unsigned long)number;
double remainder = number - (double)int_part;
Serial.print(int_part);
// Print the decimal point, but only if there are digits beyond
if (digits > 0)
Serial.print(".");
// Extract digits from the remainder one at a time
while (digits-- > 0)
remainder *= 10.0;
int toPrint = int(remainder);
Serial.print(toPrint);
remainder -= toPrint;
while (true)
char c = pgm_read_byte_near(str++);
if (!c) break;
Serial.print(c);
gps.encode(c);
gps.encode('\r');
gps.encode('\n');
long lat, lon;
float flat, flon;
unsigned long age, date, time, chars;
int year;
byte month, day, hour, minute, second, hundredths;
unsigned short sentences, failed;
gps.get_position(&lat, &lon, &age);
Serial.print("Lat/Long(10^-5 deg): "); Serial.print(lat); Serial.print(", "); Serial.print(lon);
Serial.print(" Fix age: "); Serial.print(age); Serial.println("ms.");
gps.f_get_position(&flat, &flon, &age);
Serial.print("Lat/Long(float): "); printFloat(flat); Serial.print(", "); printFloat(flon);
gps.get_datetime(&date, &time, &age);
Serial.print("Date(ddmmyy): "); Serial.print(date); Serial.print(" Time(hhmmsscc): "); Serial.print(time);
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
Serial.print("Date: "); Serial.print(static_cast<int>(month)); Serial.print("/"); Serial.print(static_cast<int>(day)); Serial.print("/"); Serial.print(year);
Serial.print(" Time: "); Serial.print(static_cast<int>(hour)); Serial.print(":"); Serial.print(static_cast<int>(minute)); Serial.print(":"); Serial.print(static_cast<int>(second)); Serial.print("."); Serial.print(static_cast<int>(hundredths));
Serial.print("Alt(cm): "); Serial.print(gps.altitude()); Serial.print(" Course(10^-2 deg): "); Serial.print(gps.course()); Serial.print(" Speed(10^-2 knots): "); Serial.println(gps.speed());
Serial.print("Alt(float): "); printFloat(gps.f_altitude(), 2); Serial.print(" Course(float): "); printFloat(gps.f_course(), 2); Serial.println();
Serial.print("Speed (knots): "); printFloat(gps.f_speed_knots(), 2); Serial.print(" (mph): "); printFloat(gps.f_speed_mph(), 2);
Serial.print(" (mps): "); printFloat(gps.f_speed_mps(), 2); Serial.print(" (kmph): "); printFloat(gps.f_speed_kmph(), 2); Serial.println();
gps.stats(&chars, &sentences, &failed);
Serial.print("Stats: characters: "); Serial.print(chars); Serial.print(" sentences: "); Serial.print(sentences); Serial.print(" failed checksum: "); Serial.println(failed);
The error is:
static_test.cpp:2:26: error: avr\pgmspace.h: No such file or directory
However if I run the PROGMEM sample code from:
http://www.arduino.cc/en/Reference/PROGMEM
this works fine.
PROGMEM string demo
How to store a table of strings in program memory (flash),
and retrieve them.
Information summarized from:
http://www.nongnu.org/avr-libc/user-manual/pgmspace.html
Setting up a table (array) of strings in program memory is slightly complicated, but
here is a good template to follow.
Setting up the strings is a two-step process. First define the strings.
prog_char string_0[] PROGMEM = "String 0"; // "String 0" etc are strings to store - change to suit.
prog_char string_1[] PROGMEM = "String 1";
prog_char string_2[] PROGMEM = "String 2";
prog_char string_3[] PROGMEM = "String 3";
prog_char string_4[] PROGMEM = "String 4";
prog_char string_5[] PROGMEM = "String 5";
// Then set up a table to refer to your strings.
PROGMEM const char *string_table[] = // change "string_table" name to suit
string_0,
string_1,
string_2,
string_3,
string_4,
string_5 };
char buffer[30]; // make sure this is large enough for the largest string it must hold
/* Using the string table in program memory requires the use of special functions to retrieve the data.
The strcpy_P function copies a string from program space to a string in RAM ("buffer").
Make sure your receiving string in RAM is large enough to hold whatever
you are retrieving from program space. */
for (int i = 0; i < 6; i++)
strcpy_P(buffer, (char*)pgm_read_word(&(string_table[i]))); // Necessary casts and dereferencing, just copy.
Serial.println( buffer );
delay( 500 );
Could someone perhaps point me to whatever I may be missing with updating TinyGPS to work with IDE 1.0.
Thanks
