Arduino Webhooks Integration
Hello,
I am trying to send data from my arduino to google sheets using a webhooks script. The following POST works when using postman:
POST /macros/s/AKfycbzOeD77Fj_qYMP9yIXcF--6VANqSGwuaoX/exec HTTP/1.1
Host: script.google.com
Content-Type: application/json
Content-Length: 36
{"value1": 10.569, "value2": 34.257}
However when I try and use the following code it does not! Does anyone knbow why this is not working. TIA
#include "ESP8266WiFi.h"
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;  // your network SSID (name)
char pass[] = SECRET_PASS;  // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;           // your network key index number (needed only for WEP)
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ;  // wait for serial port to connect. Needed for native USB port only
  // attempt to connect to WiFi network:
  Serial.printf("\nConnecting to: %s \n", ssid);
  WiFi.mode(WIFI_STA);
  status = WiFi.begin(ssid, pass);
    Serial.print('.');
  Serial.printf("\n");
  // you're connected now, so print out the data:
  Serial.println("You're connected to the network");
  printWifiStatus();
  char server[] = "script.google.com";  // name address for Google (using DNS)
  char buffer[700];
  //Serial.println("\nStarting connection to server...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected to server");
    sprintf(buffer, "");
    sprintf(buffer, "%sPOST /macros/s/AKfycbzOeD77Fj_qYMP9yIXcF-hLWihcbQoMi6lU5ASjesiKIFurpjD860C-6VANqSGwuaoX/exec HTTP/1.1\n", buffer);
    sprintf(buffer, "%sHost: script.google.com\n", buffer);
    sprintf(buffer, "%sContent-Type: application/json\n", buffer);
    sprintf(buffer, "%sConnection: close\n", buffer);
    sprintf(buffer, "%sContent-Length: 36\n", buffer);
    sprintf(buffer, "%s{\"value1\": 10.569, \"value2\": 34.257}\n", buffer);
    Serial.printf("Sending:\n%s", buffer);
    client.println(buffer);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting from server.");
    client.stop();
  delay(2000);
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Google Scripts require HTTPS, not plain HTTP on port 80. (Postman works because it uses HTTPS automatically)
➜ you need to use WiFiClientSecure and port 443
also HTTP requires each header line to end with CRLF , Using only \n
can cause the server to ignore or reject the request.
➜ You should use \r\n
Also the headers must be followed by a blank line before the body so you should have a double \r\n after the content length and before the values
You should not use sprintf() the way you do, why don't you just either print directly to the client without creating a huge buffer on your side or use strlcpy() if you really want to have the buffer?
➜ something like this
WiFiClientSecure client;
if (client.connect("script.google.com", 443)) {
  client.print("POST /macros/s/XXXXXX/exec HTTP/1.1\r\n");
  client.print("Host: script.google.com\r\n");
  client.print("Content-Type: application/json\r\n");
  client.print("Connection: close\r\n");
  client.print("Content-Length: 36\r\n");
  client.print("\r\n");
  client.print("{\"value1\": 10.569, \"value2\": 34.257}\r\n");
Please advertise HTTP 1.0 when stuff like Transfer-Encoding: chunked is not implemented.
fair point when it matters
Thanks all, that worked a treat, just needed to include client.setInsecure();
Dunno how much is intention versus luck, but println uses "\r\n"
$ rg -A 3 '\bPrint::println\(\s*(void)?\s*\)' ~/Library/Arduino15/packages
/Users/kenb4/Library/Arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/api/Print.cpp
149:size_t Print::println(void)
150-{
151-  return write("\r\n");
152-}
/Users/kenb4/Library/Arduino15/packages/arduino/hardware/mbed_portenta/4.2.4/cores/arduino/api/Print.cpp
150:size_t Print::println(void)
151-{
152-  return write("\r\n");
153-}
/Users/kenb4/Library/Arduino15/packages/Seeeduino/hardware/samd/1.8.5/cores/arduino/Print.cpp
111:size_t Print::println(void)
112-{
113-  return write("\r\n");
114-}
/Users/kenb4/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4/Print.cpp
85:size_t Print::println(void)
86-{
87-	uint8_t buf[2]={'\r', '\n'};
88-	return write(buf, 2);
/Users/kenb4/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy3/Print.cpp
79:size_t Print::println(void)
80-{
81-	uint8_t buf[2]={'\r', '\n'};
82-	return write(buf, 2);
/Users/kenb4/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy/Print.cpp
86-{
/Users/kenb4/Library/Arduino15/packages/arduino/hardware/mbed_giga/4.3.1/cores/arduino/api/Print.cpp
151-{
153-}
/Users/kenb4/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.8/cores/arduino/api/Print.cpp
150-{
152-}
/Users/kenb4/Library/Arduino15/packages/arduino/hardware/esp32/2.0.18-arduino.5/cores/esp32/Print.cpp
169:size_t Print::println(void)
170-{
171-    return print("\r\n");
172-}
/Users/kenb4/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.2/cores/arduino/api/Print.cpp
151-{
153-}
/Users/kenb4/Library/Arduino15/packages/arduino/hardware/mbed_opta/4.2.1/cores/arduino/api/Print.cpp
151-{
153-}
/Users/kenb4/Library/Arduino15/packages/m5stack/hardware/esp32/2.1.1/cores/esp32/Print.cpp
170-{
172-}
/Users/kenb4/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/Print.cpp
126:size_t Print::println(void)
127-{
128-  return write("\r\n");
129-}
/Users/kenb4/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/cores/esp8266/Print.cpp
180:size_t Print::println(void) {
181-    return print("\r\n");
182-}
183-
/Users/kenb4/Library/Arduino15/packages/esp32/hardware/esp32/3.0.7/cores/esp32/Print.cpp
169:size_t Print::println(void) {
170-  return print("\r\n");
171-}
172-
(Check out Teensy though.) So you can just have
  client.println("POST /macros/s/XXXXXX/exec HTTP/1.1");
  client.println("Host: script.google.com");
  client.println("Content-Type: application/json");
  client.println("Content-Length: 36");
  client.println("Connection: close");
  client.println();  // don't need empty string here -- note there is no `print()` with no args
  client.print(R"({"value1": 10.569, "value2": 34.257})");  // don't need "\r\n" after content
(The raw string makes the JSON literal a little less tedious. And if you're not going to have the compiler count the Content-Length for you, it's also a little easier to spot-check that manual length is correct.)
Yes, I hesitated putting that and thought it would be clearer having the CRLF in the string as per the point I was trying to make. But you are right, that’s the better way.
Thanks for your help but I have a similar but different question. I have a similar project but using an arduino R4 so am having to use a different library.
It sometimes connects but then after a few trys will not connect. Any ideas what I am doing wrong?
The code is below:
// This example uses an Arduino Uno together with
// a WiFi Shield to connect to shiftr.io.
// You can check on your device after a successful
// connection here: https://www.shiftr.io/try.
// by Joël Gähwiler
// https://github.com/256dpi/arduino-mqtt
#include <WiFiS3.h>
#include <WiFiSSLClient.h>
//Google webhooks
char host[] = "script.google.com";
int port = 443;
char url[] = "/macros/s/####/exec";
int status = WL_IDLE_STATUS;  // the WiFi radio's status
//Calibration Data
const float V_REF = 5.0;                         // Analog reference voltage (e.g., 5V or 3.3V)
const float R_BITS = 10.0;                       // ADC resolution (bits)
const float ADC_STEPS = (1 << int(R_BITS)) - 1;  // Number of steps (2^R_BITS - 1)
const float ZERO_OFFSET = 2.515;                 // Zero Offset of Ammeter
const float VperA = .072;                        //Volts per Amp on Ammeter
const int VoltagePin = A0;  // Voltage measurement on analogue Pin 1
const int CurrentPin = A1;  // Current measurement on analogue Pin 0
long lastMillis = 0;
WiFiSSLClient client;
float readADC(int pin)  //Returns the voltage of the analouge port defined by pin
  unsigned int x = 0;
  float ADCValue = 0.0, Samples = 0.0, AvgADC = 0.0, Volts = 0.0;
  for (int x = 0; x < 150; x++) {  //Get 150 samples
    ADCValue = analogRead(pin);    //Read current sensor values
    Samples = Samples + ADCValue;  //Add samples together
    delay(3);                      // let ADC settle before next sample 3ms
  AvgADC = Samples / 150.0;  //Taking Average of Samples and turn into voltage
  Volts = V_REF * AvgADC / ADC_STEPS;
  return Volts;
void printWifiData() {
  Serial.println(ip);
  // print your MAC address:
  byte mac[6];
  WiFi.macAddress(mac);
  char macstr[17];
  mac2str(macstr, mac);
  Serial.print("Device MAC Address: ");
  Serial.println(macstr);
void printCurrentNet() {
  // print the MAC address of the router you're attached to:
  byte bssid[6];
  WiFi.BSSID(bssid);
  Serial.print("BSSID: ");
  char macstr[17];
  mac2str(macstr, bssid);
  Serial.println(rssi);
  // print the encryption type:
  byte encryption = WiFi.encryptionType();
  Serial.print("Encryption Type:");
  Serial.println(encryption, HEX);
void mac2str(char* macstr, byte mac[6]) {
  sprintf(macstr, "%02X:%02X:%02X:%02X:%02X:%02X", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
  while (!Serial) {
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    // wait 2 seconds for connection:
    delay(2000);
  printCurrentNet();
  printWifiData();
  //Set certificate
  client.setCACert(root_ca);
  float voltage, current;
  char buffer[36];
  if (millis() - lastMillis > 5 * 1000) {
    voltage = 25 * readADC(VoltagePin) / 5;
    current = (readADC(CurrentPin) - ZERO_OFFSET) / VperA;
    lastMillis = millis();
    //Output to google sheets
    if (client.connect(host, port)) {
      client.print("POST ");
      client.print(url);
      client.println("HTTP/1.1");
      client.print("Host: ");
      client.print(host);
      client.println("");
      client.println("");
      sprintf(buffer, "{\"voltage\":%6.2f, \"current\":%6.2f}", voltage, current);
      Serial.println("Client not connected.");
      client.stop();
Please check:
  • not requesting HTTP 1.0
  • hardcoded content length (needs to be strlen of buffer)
  • probably no space for string termination in buffer
  • sprintf does no buffer size check (use snprintf)
  • not reading response from server
I have tried that and still no connection. see below:
// by Joël Gähwiler
#include <WiFiS3.h>
//Google webhooks
int port = 443;
char url[] = "/macros/s/AKfycbxc_m555AsnBqiVJxi3SU4xox07Ig2ZR6xPzFuuF4IML1Qi_e3-U192oXbUrFTo7L06/exec";
//Calibration Data
  unsigned int x = 0;
  return Volts;
  Serial.println(ip);
  byte mac[6];
  char macstr[17];
  byte bssid[6];
  WiFi.BSSID(bssid);
  char macstr[17];
  while (!Serial) {
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
    delay(2000);
  printCurrentNet();
  printWifiData();
  //Set certificate
/* just wrap the received data up to 80 columns in the serial print*/
void read_response() {
  uint32_t received_data_num = 0;
  while (client.available()) {
    /* actual data reception */
    char c = client.read();
    /* print data to serial port */
    Serial.print(c);
    /* wrap data to 80 columns*/
    received_data_num++;
    if (received_data_num % 80 == 0) {
  char buffer[50];
      client.print(url);
      client.println("HTTP/1.0");
      client.print(host);
      client.println("");
      snprintf(buffer, 50, "");
      snprintf(buffer, 50, "{\"voltage\":%6.2f, \"current\":%6.2f}", voltage, current);
      client.print("Content-Length: ");
      client.println(strlen(buffer));
      client.println("");
      read_response();
      client.stop();
Do you get any error response from the server?
No need for a line break after sending the buffer.
There need to be a space between url and the HTTP version.
That doesn't seem to be a response. However it never connects so the HTML request is never sent
Maybe something is wrong with the CA. Try with setting the client to insecure.
On R4 (which has dozens of CA certs baked into the firmware, and no setInsecure) this seems to work consistently to connect on demand
#include <WiFi.h>
WiFiSSLClient ssl;
auto host = "script.google.com";
  WiFi.begin(SECRET_SSID, SECRET_PASS);  // blocking with R4
  if (WiFi.status() != WL_CONNECTED) {
    Serial.print("Failed to connected to: ");
    Serial.println(SECRET_SSID);
    for (;;);
  Serial.print("Connected as: ");
  static bool prompt = true;
  if (prompt) {
    prompt = false;
    Serial.println("Press Enter to connect");
  if (Serial.available() <= 0) {
    delay(100);
    return;
  prompt = true;
  Serial.println("Connecting to host....");
  Serial.readStringUntil('\n');
  if (ssl.connect(host, 443)) {
    ssl.println("GET /.well-known/token_endpoint HTTP/1.0");
    ssl.println();
    uint8_t buf[80];
    while (ssl.connected()) {
      if (ssl.available() > 0) {
        auto len = ssl.read(buf, sizeof(buf));
        Serial.write(buf, len);
    ssl.stop();
    Serial.print("Failed to connect to: ");
    Serial.println(host);
Note that the actual /.well-known path is irrelevant -- the question is whether it connects or not. A 404 response still means it worked.
