Hi all
I'm trying to create a small web server that reads a get command ex I send http://192.168.1.31?distance=5 where my arduino server is 192.168.1.31 and I need to read the value of distance.
I'm using WiFiNINA.h libary.
Yes I have, but there are no easy way to to this and I think I'm missing something....
That example does almost the same as you're trying to do. Minimal modifications are necessary. Don't expect us to do your job, this is not a free programming service.
mskovborg:
Hi all
Can any one help me with this?
Well, it depends on the library being used and its functions, and the functions are used in the code. The below is what is typically sent by a client to a server, with the data in the first line being of interest. Usually that first line is captured as a c-string or String, then various operations are used to extract the desired data. In your example "GET ?distance=5 HTTP/1.1" would probably be the first line. With the line being captured as a String, a String function could extract the data between the = and the next blank space and save that as a variable, which could be used or displayed. In this case it would be the "5".
GET /2/on HTTP/1.1
Accept: text/html, application/xhtml+xml, image/jxr, */*
Accept-Language: en-US
User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64; Trident/7.0; rv:11.0) like Gecko
Accept-Encoding: gzip, deflate
Host: 192.168.0.2
DNT: 1
Connection: Keep-Alive
Hi zoomkat
Thanks for your reply.
It looks like C is missing some lib's to make life easy for programmers
I will take a look into a way to split the string and get the values.
