Last login: Mon Apr 22 14:35:10 on console
/Users/danriebs/.zprofile:1: no such file or directory: /opt/homebrew/bin/brew
danriebs@Dans-Mac-mini ~ % "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.3.3-nightly-20240420
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
2024-04-23 09:52:54.924 Arduino IDE[16002:461783] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3-nightly-20240420" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.36.0-rc.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-04-20T03:17:18.603Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3-nightly-20240420","cliVersion":"0.36.0-rc.1","buildDate":"2024-04-20T03:17:18.603Z"}
Starting backend process. PID: 16032
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/danriebs/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-04-23T14:52:56.293Z root INFO Backend Object.initialize: 45.7 ms [Finished 1.120 s after backend start]
2024-04-23T14:52:56.311Z root INFO Backend Object.configure: 32.4 ms [Finished 1.122 s after backend start]
2024-04-23T14:52:56.311Z root INFO Backend a.onStart: 19.0 ms [Finished 1.122 s after backend start]
2024-04-23T14:52:56.319Z root INFO Backend a.configure: 9.5 ms [Finished 1.201 s after backend start]
2024-04-23T14:52:56.338Z root INFO Backend d.onStart: 4.0 ms [Finished 1.201 s after backend start]
2024-04-23T14:52:56.342Z root INFO Backend d.configure: 1.9 ms [Finished 1.203 s after backend start]
2024-04-23T14:52:56.358Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 84.6 ms [Finished 1.212 s after backend start]
2024-04-23T14:52:56.363Z root INFO Backend c.onStart: 8.9 ms [Finished 1.212 s after backend start]
2024-04-23T14:52:56.377Z root INFO Backend s.configure: 21.4 ms [Finished 1.235 s after backend start]
2024-04-23T14:52:56.379Z config INFO >>> Initializing CLI configuration...
2024-04-23T14:52:56.382Z root INFO Backend c.initialize: 4.2 ms [Finished 1.240 s after backend start]
2024-04-23T14:52:56.382Z root INFO Backend x.onStart: 15.4 ms [Finished 1.253 s after backend start]
2024-04-23T14:52:56.384Z config INFO Loading CLI configuration from /Users/danriebs/.arduinoIDE/arduino-cli.yaml...
2024-04-23T14:52:56.387Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-04-23T14:52:56.387Z root INFO Backend s.initialize: 1.1 ms [Finished 1.264 s after backend start]
2024-04-23T14:52:56.387Z root INFO Backend w.onStart: 15.9 ms [Finished 1.279 s after backend start]
2024-04-23T14:52:56.387Z root INFO Backend r.configure: 30.0 ms [Finished 1.285 s after backend start]
2024-04-23T14:52:56.390Z discovery-log INFO start
2024-04-23T14:52:56.390Z discovery-log INFO start new deferred
2024-04-23T14:52:56.390Z root INFO Backend d.initialize: 12.7 ms [Finished 1.298 s after backend start]
2024-04-23T14:52:56.390Z root INFO Backend y.onStart: 17.0 ms [Finished 1.303 s after backend start]
2024-04-23T14:52:56.390Z root INFO Backend r.configure: 5.1 ms [Finished 1.304 s after backend start]
2024-04-23T14:52:56.390Z root INFO Backend s.onStart: 3.2 ms [Finished 1.309 s after backend start]
2024-04-23T14:52:56.390Z root INFO Backend h.configure: 2.8 ms [Finished 1.309 s after backend start]
2024-04-23T14:52:56.390Z root INFO Backend a.configure: 0.5 ms [Finished 1.311 s after backend start]
2024-04-23T14:52:56.390Z root INFO Backend l.configure: 0.1 ms [Finished 1.312 s after backend start]
2024-04-23T14:52:56.420Z root INFO Theia app listening on http://127.0.0.1:60284.
2024-04-23T14:52:56.424Z root INFO Finished starting backend application: 26.9 ms [Finished 1.340 s after backend start]
2024-04-23T14:52:56.441Z root WARN The local plugin referenced by local-dir:/Users/danriebs/.arduinoIDE/plugins does not exist.
2024-04-23T14:52:56.443Z root WARN The local plugin referenced by local-dir:/Users/danriebs/.arduinoIDE/extensions does not exist.
2024-04-23T14:52:56.646Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://espressif.github.io/arduino-esp32/package_esp32_index.json","https://espressif.github.io/arduino-esp32/package_esp32_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"/Users/danriebs/Library/Arduino15","downloads":"/Users/danriebs/Library/Arduino15/staging","user":"/Users/danriebs/Robot/programming"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-04-23T14:52:56.646Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-04-23T14:52:56.646Z config INFO Loaded the CLI configuration.
Restoring workspace roots: /Users/danriebs/Robot/programming/client/client1_4
isTempSketch: false. Input was /Users/danriebs/Robot/programming/client/client1_4/client1_4.ino
2024-04-23T14:52:56.871Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/danriebs/Library/Arduino15","sketchDirUri":"file:///Users/danriebs/Robot/programming","additionalUrls":["https://espressif.github.io/arduino-esp32/package_esp32_index.json"],"network":"none","locale":"en"}
2024-04-23T14:52:56.871Z config INFO Validating the CLI configuration...
2024-04-23T14:52:57.024Z daemon INFO time="2024-04-23T09:52:56-05:00" level=info msg="Using config file: /Users/danriebs/.arduinoIDE/arduino-cli.yaml"
time="2024-04-23T09:52:56-05:00" level=info msg="arduino-cli version 0.36.0-rc.1"
time="2024-04-23T09:52:56-05:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:60285
{"IP":"127.0.0.1","Port":"60285"}
2024-04-23T14:52:57.024Z daemon INFO Daemon is running.
2024-04-23T14:52:57.031Z config INFO The CLI config is valid.
2024-04-23T14:52:57.031Z config INFO <<< Initialized the CLI configuration.
2024-04-23T14:52:57.853Z daemon INFO time="2024-04-23T09:52:57-05:00" level=info msg="Checking signature" index=/Users/danriebs/Library/Arduino15/package_index.json signatureFile=/Users/danriebs/Library/Arduino15/package_index.json.sig trusted=true
2024-04-23T14:52:57.853Z daemon INFO time="2024-04-23T09:52:57-05:00" level=info msg="Missing signature file" index=/Users/danriebs/Library/Arduino15/package_esp32_index.json
2024-04-23T14:52:57.855Z daemon INFO time="2024-04-23T09:52:57-05:00" level=info msg="Missing signature file" index=/Users/danriebs/Library/Arduino15/package_esp32_index.json
time="2024-04-23T09:52:57-05:00" level=info msg="Loading hardware from: /Users/danriebs/Library/Arduino15/packages"
2024-04-23T14:52:57.855Z daemon INFO time="2024-04-23T09:52:57-05:00" level=info msg="Loading package builtin from: /Users/danriebs/Library/Arduino15/packages/builtin"
time="2024-04-23T09:52:57-05:00" level=info msg="Checking existence of 'tools' path: /Users/danriebs/Library/Arduino15/packages/builtin/tools"
2024-04-23T14:52:57.855Z daemon INFO time="2024-04-23T09:52:57-05:00" level=info msg="Loading tools from dir: /Users/danriebs/Library/Arduino15/packages/builtin/tools"
2024-04-23T14:52:57.857Z daemon INFO time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-04-23T09:52:57-05:00" level=info msg="Loading package esp32 from: /Users/danriebs/Library/Arduino15/packages/esp32/hardware"
2024-04-23T14:52:57.860Z daemon INFO time="2024-04-23T09:52:57-05:00" level=info msg="Missing signature file" index=/Users/danriebs/Library/Arduino15/packages/esp32/hardware/esp32/3.0.0-rc1/installed.json
2024-04-23T14:52:57.868Z root INFO Resolve plugins list: 1485.3 ms [Finished 2.789 s after backend start]
2024-04-23T14:52:58.014Z daemon INFO time="2024-04-23T09:52:57-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded platform" platform="esp32:esp32@3.0.0-rc1"
time="2024-04-23T09:52:57-05:00" level=info msg="Checking existence of 'tools' path: /Users/danriebs/Library/Arduino15/packages/esp32/tools"
time="2024-04-23T09:52:57-05:00" level=info msg="Loading tools from dir: /Users/danriebs/Library/Arduino15/packages/esp32/tools"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:esp-rv32@2302"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:esp32-arduino-libs@idf-release_v5.1-3662303f312"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.6"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20230921"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@12.1_20231023"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@12.1_20231023"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-12.2.0_20230208"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-12.2.0_20230208"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-12.2.0_20230208"
time="2024-04-23T09:52:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-04-23T09:52:58-05:00" level=info msg="Adding libraries dir" dir=/Users/danriebs/Library/Arduino15/packages/esp32/hardware/esp32/3.0.0-rc1/libraries isSingleLibrary=false location=platform
time="2024-04-23T09:52:58-05:00" level=info msg="Loading libraries index file" index=/Users/danriebs/Library/Arduino15/library_index.json
2024-04-23T14:52:58.534Z daemon INFO time="2024-04-23T09:52:58-05:00" level=info msg="Adding libraries dir" dir=/Users/danriebs/Library/Arduino15/libraries isSingleLibrary=false location=ide
time="2024-04-23T09:52:58-05:00" level=info msg="Adding libraries dir" dir=/Users/danriebs/Robot/programming/libraries isSingleLibrary=false location=user
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/HTTPRequest: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/UDP: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/WiFiUDP: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/arduino-esp32-master: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/esp: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/esp-idf-be06a6f5ffe36f9554cfc91fe2036e0fc85fea60: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/esp-lwip-2.1.2-esp: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/esp32-pcap-main: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/esp_WiFi: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/lwip: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/macOS_VCP_Driver: invalid library: no header files found"
time="2024-04-23T09:52:58-05:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from /Users/danriebs/Robot/programming/libraries/muduo: invalid library: no header files found"
2024-04-23T14:52:58.611Z discovery-log INFO start resolved watching
2024-04-23T14:52:58.619Z daemon INFO time="2024-04-23T09:52:58-05:00" level=info msg="starting discovery builtin:serial-discovery process"
time="2024-04-23T09:52:58-05:00" level=info msg="starting discovery builtin:mdns-discovery process"
2024-04-23T14:52:58.663Z daemon INFO time="2024-04-23T09:52:58-05:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2024-04-23T09:52:58-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.36.0-rc.1\" to discovery builtin:mdns-discovery"
time="2024-04-23T09:52:58-05:00" level=info msg="started discovery builtin:serial-discovery process"
time="2024-04-23T09:52:58-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.36.0-rc.1\" to discovery builtin:serial-discovery"
time="2024-04-23T09:52:58-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
time="2024-04-23T09:52:58-05:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
time="2024-04-23T09:52:58-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
time="2024-04-23T09:52:58-05:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
time="2024-04-23T09:52:58-05:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2024-04-23T09:52:58-05:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
time="2024-04-23T09:52:58-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.wlan-debug"
time="2024-04-23T09:52:58-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.Bluetooth-Incoming-Port"
time="2024-04-23T09:52:58-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.usbserial-0001"
time="2024-04-23T09:52:58-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.SLAB_USBtoUART"
time="2024-04-23T09:52:58-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.usbmodem221402"
2024-04-23T14:52:58.694Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.wlan-debug","label":"/dev/cu.wlan-debug","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-04-23T14:52:58.736Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.Bluetooth-Incoming-Port","label":"/dev/cu.Bluetooth-Incoming-Port","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-04-23T14:52:58.763Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.usbserial-0001","label":"/dev/cu.usbserial-0001","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0xEA60"],["serialNumber","0001"],["vid","0x10C4"]],"hardwareId":"0001"}},"error":""}
2024-04-23T14:52:58.765Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.SLAB_USBtoUART","label":"/dev/cu.SLAB_USBtoUART","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0xEA60"],["serialNumber","0001"],["vid","0x10C4"]],"hardwareId":"0001"}},"error":""}
2024-04-23T14:52:58.767Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Arduino Uno WiFi Rev2","fqbn":"arduino:megaavr:uno2018","isHidden":false}],"port":{"address":"/dev/cu.usbmodem221402","label":"/dev/cu.usbmodem221402","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x2145"],["serialNumber","F0A263254B1CCEE824AC"],["vid","0x03EB"]],"hardwareId":"F0A263254B1CCEE824AC"}},"error":""}
2024-04-23T14:53:00.215Z root INFO Deploy plugins list: 1485.3 ms [Finished 5.136 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-04-23T14:53:04.494Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 1376.5 ms [Finished 7.423 s after frontend start]
2024-04-23T14:53:04.574Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-04-23T14:53:04.738Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: </Users/danriebs/Robot/programming/client/client1_4/client1_4.ino>, response: </Users/danriebs/Robot/programming/client/client1_4>.
2024-04-23T14:53:05.127Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 247.9 ms [Finished 7.754 s after frontend start]
2024-04-23T14:53:05.146Z root WARN Frontend menus.onStart took longer than the expected maximum 100 milliseconds: 357.1 ms [Finished 8.129 s after frontend start]
2024-04-23T14:53:05.707Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 485.5 ms [Finished 8.697 s after frontend start]
2024-04-23T14:53:06.436Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 726.2 ms [Finished 9.447 s after frontend start]
2024-04-23T14:53:06.746Z root INFO Start frontend contributions: 4095.1 ms [Finished 9.458 s after frontend start]
2024-04-23T14:53:06.746Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-04-23T14:53:06.876Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-04-23T14:53:06.876Z root INFO >>> Restoring the layout state...
2024-04-23T14:53:06.883Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-04-23T14:53:06.885Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///Users/danriebs/Robot/programming/client/client1_4/client1_4.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":23,\"column\":1},\"position\":{\"lineNumber\":23,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":3,\"column\":1},\"firstPositionDeltaTop\":-10},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":39,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"serial-monitor"}},{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":1}},"pinned":[false,false],"size":182,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"code-editor-opener:file:///Users/danriebs/Robot/programming/client/client1_4/client1_4.ino:0"}
2024-04-23T14:53:06.885Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-04-23T14:53:07.038Z root INFO [aee8d2f0-b6a2-4e3f-bd00-8f3faacc9437] Waiting for backend deployment: 597.0 ms [Finished 10.046 s after frontend start]
2024-04-23T14:53:08.077Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040) starting instance
2024-04-23T14:53:08.920Z root INFO [aee8d2f0-b6a2-4e3f-bd00-8f3faacc9437] Sync of 23 plugins: 1883.7 ms [Finished 11.929 s after frontend start]
2024-04-23 09:53:09.235 Arduino IDE Helper (Renderer)[16034:462027] CoreText note: Client requested name ".NewYork-Regular", it will get TimesNewRomanPSMT rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
2024-04-23 09:53:09.235 Arduino IDE Helper (Renderer)[16034:462027] CoreText note: Set a breakpoint on CTFontLogSystemFontNameRequest to debug.
2024-04-23T14:53:09.760Z root INFO <<< The layout has been successfully restored.
2024-04-23T14:53:10.024Z root INFO Initialize the workbench layout: 2914.4 ms [Finished 12.772 s after frontend start]
2024-04-23T14:53:10.028Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-04-23T14:53:10.028Z root INFO [aee8d2f0-b6a2-4e3f-bd00-8f3faacc9437] Loading plugin contributions
2024-04-23T14:53:10.028Z root INFO [aee8d2f0-b6a2-4e3f-bd00-8f3faacc9437] Load contributions of 23 plugins: 261.3 ms [Finished 13.035 s after frontend start]
2024-04-23T14:53:10.065Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-04-23T14:53:10.065Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-04-23T14:53:13.543Z root INFO Frontend application start: 9180.4 ms [Finished 18.464 s after backend start]
2024-04-23T14:53:13.596Z root INFO Replace loading indicator with ready workbench UI (animation): 3189.1 ms [Finished 16.229 s after frontend start]
2024-04-23T14:53:13.607Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-04-23T14:53:13.607Z root WARN Linked preference "workbench.colorCustomizations" not found.
Checking for update
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <debug.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <dataRX.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <dataTX.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <dec2int.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <Socket0.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <central.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <socket0.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <blink.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <extra.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <AsyncClient.ino> and sketch folder name <AsyncTCP1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <extra.ino> and sketch folder name <AsyncWebServer1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <callback.ino> and sketch folder name <ESP32Client1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <blink.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <extra.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <IP_Services.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <callback.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <incoming.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <Async1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <clientConnect.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <serverConnect.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <Async1_1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <runMotorFromFile.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <runMotorFromWiFi.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <AsyncWebServer1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <read_incoming.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <local_overlay.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <TCPServer1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <write_outgoing.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32Client>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <registration_utils.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <read_incoming.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <receive.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32Client0>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32Client1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <TCPServer1_1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <TCPServer1_2>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <write_outgoing.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_3>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_4>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_5>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <overlays.ino> and sketch folder name <ESP32AsyncWebServer8_6>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_6>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <overlays.ino> and sketch folder name <ESP32AsyncWebServer8_7>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_7>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <overlays.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <AsyncWebServer1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <ESP32AsyncWebServer8>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <ESP32AsyncWebServer8_1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <ESP32AsyncWebServer8_2>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <ESP32AsyncWebServer8_3>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <ESP32AsyncWebServer8_4>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <prototype_motor_function.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_2>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_3>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_4>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_5>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_6>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_7>. Skipping
2024-04-23 09:53:13.854 Arduino IDE Helper (Renderer)[16034:462027] CoreText note: Client requested name ".NewYork-Regular", it will get TimesNewRomanPSMT rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <methods_and_properties_library.ino> and sketch folder name <AsyncWebServer1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <methods_and_properties_library.ino> and sketch folder name <ESP32AsyncWebServer8>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <methods_and_properties_library.ino> and sketch folder name <ESP32AsyncWebServer8_1>. Skipping
2024-04-23T14:53:13.833Z sketches-service WARN Mismatching sketch file <methods_and_properties_library.ino> and sketch folder name <ESP32AsyncWebServer8_2>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <debug.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <dataRX.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <dataTX.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <dec2int.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <Socket0.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <central.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <socket0.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <blink.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <extra.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <AsyncClient.ino> and sketch folder name <AsyncTCP1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <extra.ino> and sketch folder name <AsyncWebServer1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <callback.ino> and sketch folder name <ESP32Client1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <blink.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <extra.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <IP_Services.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <callback.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <incoming.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <Async1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <clientConnect.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <serverConnect.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <Async1_1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <runMotorFromFile.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <runMotorFromWiFi.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <AsyncWebServer1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <read_incoming.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <local_overlay.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <TCPServer1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <write_outgoing.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32Client>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <registration_utils.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <read_incoming.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <receive.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32Client0>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32Client1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <TCPServer1_1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <TCPServer1_2>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <write_outgoing.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_3>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_4>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_5>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <overlays.ino> and sketch folder name <ESP32AsyncWebServer8_6>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_6>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <overlays.ino> and sketch folder name <ESP32AsyncWebServer8_7>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_7>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <overlays.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
2024-04-23T14:53:14.275Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <AsyncWebServer1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <ESP32AsyncWebServer8>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <ESP32AsyncWebServer8_1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <ESP32AsyncWebServer8_2>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <ESP32AsyncWebServer8_3>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <ESP32AsyncWebServer8_4>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <prototype_motor_function.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_2>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_3>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_4>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_5>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_6>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_7>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <methods_and_properties_library.ino> and sketch folder name <AsyncWebServer1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <methods_and_properties_library.ino> and sketch folder name <ESP32AsyncWebServer8>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <methods_and_properties_library.ino> and sketch folder name <ESP32AsyncWebServer8_1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <methods_and_properties_library.ino> and sketch folder name <ESP32AsyncWebServer8_2>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <debug.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <dataRX.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <dataTX.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <dec2int.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <Socket0.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <central.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <socket0.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <blink.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <extra.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <AsyncClient.ino> and sketch folder name <AsyncTCP1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <extra.ino> and sketch folder name <AsyncWebServer1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <callback.ino> and sketch folder name <ESP32Client1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <blink.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <extra.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <IP_Services.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <callback.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <incoming.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <Async1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <clientConnect.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <serverConnect.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <Async1_1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <runMotorFromFile.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <runMotorFromWiFi.ino> and sketch folder name <RobotMain0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <packet_codes.ino> and sketch folder name <AsyncWebServer1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <read_incoming.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <local_overlay.ino> and sketch folder name <ESP32AsyncWiFi>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <TCPServer1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <write_outgoing.ino> and sketch folder name <client1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32Client>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <registration_utils.ino> and sketch folder name <RobotMain3>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <read_incoming.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <receive.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32Client0>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <ESP32Client1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <TCPServer1_1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <buffer_management.ino> and sketch folder name <TCPServer1_2>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <write_outgoing.ino> and sketch folder name <client1_1>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_3>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_4>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_5>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <overlays.ino> and sketch folder name <ESP32AsyncWebServer8_6>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_6>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <overlays.ino> and sketch folder name <ESP32AsyncWebServer8_7>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_7>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <overlays.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
2024-04-23T14:53:14.276Z sketches-service WARN Mismatching sketch file <transmit.ino> and sketch folder name <ESP32AsyncWebServer8_8>. Skipping
Found version 2.3.2 (url: arduino-ide_2.3.2_macOS_64bit.zip, arduino-ide_2.3.2_macOS_64bit.dmg, arduino-ide_2.3.2_macOS_arm64.zip, arduino-ide_2.3.2_macOS_arm64.dmg)
2024-04-23T14:53:15.815Z root ERROR ---- !!!SLOW!!! DURATION: search took 2053.957 ms. Args: [{"type":"Updatable"}] ----
2024-04-23T14:53:15.815Z root ERROR [hosted-plugin: 16040] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-04-23T14:53:15.867Z daemon INFO time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:esp-rv32@2302"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:esp32-arduino-libs@idf-release_v5.1-3662303f312"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.6"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:mkspiffs@0.2.3"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:openocd-esp32@v0.12.0-esp32-20230921"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@12.1_20231023"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp-elf-gdb@12.1_20231023"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32-elf-gcc@esp-12.2.0_20230208"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s2-elf-gcc@esp-12.2.0_20230208"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s3-elf-gcc@esp-12.2.0_20230208"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.14.1"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.0"
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2024-04-23T09:53:15-05:00" level=info msg="Starting monitor process" monitor=serial-monitor
time="2024-04-23T09:53:15-05:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2024-04-23T14:53:15.888Z root ERROR Failed to get debug config: esp32:esp32:esp32da:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none, undefined Error: 3 INVALID_ARGUMENT: Missing programmer
at t.callErrorFromStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:796327)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:821643)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:817523)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:816968)
at /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:903090
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at a.makeUnaryRequest (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:821184)
at a.isDebugSupported (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:887987)
at /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:82008
at new Promise (<anonymous>)
at y.checkDebugEnabled (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:81986)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async u.onRequest (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:1139899)
at async c.handleRequest (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:1130794)
2024-04-23T14:53:15.889Z root ERROR Request checkDebugEnabled failed with error: 3 INVALID_ARGUMENT: Missing programmer Error: 3 INVALID_ARGUMENT: Missing programmer
for call at
2024-04-23T14:53:15.889Z daemon INFO time="2024-04-23T09:53:15-05:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
time="2024-04-23T09:53:15-05:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 0.36.0-rc.1\"" monitor=serial-monitor
2024-04-23T14:53:15.899Z daemon INFO time="2024-04-23T09:53:15-05:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2024-04-23T14:53:15.899Z daemon INFO time="2024-04-23T09:53:15-05:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
2024-04-23T14:53:15.899Z daemon INFO time="2024-04-23T09:53:15-05:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
2024-04-23T14:53:15.900Z daemon INFO time="2024-04-23T09:53:15-05:00" level=info msg="sending command" command=QUIT monitor=serial-monitor
2024-04-23T14:53:15.900Z daemon INFO time="2024-04-23T09:53:15-05:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
2024-04-23T14:53:15.900Z daemon INFO time="2024-04-23T09:53:15-05:00" level=info msg="Killing monitor process" monitor=serial-monitor
2024-04-23T14:53:15.901Z daemon INFO time="2024-04-23T09:53:15-05:00" level=error msg="stopped decode loop: EOF" monitor=serial-monitor
2024-04-23T14:53:15.901Z daemon INFO time="2024-04-23T09:53:15-05:00" level=info msg="Monitor process killed" monitor=serial-monitor
2024-04-23T14:53:16.087Z monitor-service INFO starting monitor
2024-04-23T14:53:16.140Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="Starting monitor process" monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 0.36.0-rc.1\"" monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command=QUIT monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=info msg="Killing monitor process" monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=error msg="stopped decode loop: EOF" monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=info msg="Monitor process killed" monitor=serial-monitor
2024-04-23T14:53:16.141Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="Starting monitor process" monitor=serial-monitor
2024-04-23T14:53:16.152Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
2024-04-23T14:53:16.153Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 0.36.0-rc.1\"" monitor=serial-monitor
2024-04-23T14:53:16.159Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2024-04-23T14:53:16.159Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
2024-04-23T14:53:16.159Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
2024-04-23T14:53:16.160Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command="CONFIGURE baudrate 115200" monitor=serial-monitor
2024-04-23T14:53:16.160Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="received message" error=false event_type=configure message=OK monitor=serial-monitor
2024-04-23T14:53:16.161Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command="CONFIGURE bits 8" monitor=serial-monitor
2024-04-23T14:53:16.161Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="received message" error=false event_type=configure message=OK monitor=serial-monitor
2024-04-23T14:53:16.161Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command="CONFIGURE dtr off" monitor=serial-monitor
2024-04-23T14:53:16.161Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): PluginManagerExtImpl/init()
2024-04-23T14:53:16.161Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command="CONFIGURE parity none" monitor=serial-monitor
time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command="CONFIGURE rts off" monitor=serial-monitor
2024-04-23T14:53:16.161Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command="CONFIGURE stop_bits 1" monitor=serial-monitor
2024-04-23T14:53:16.162Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="sending command" command="OPEN 127.0.0.1:60309 /dev/cu.usbserial-0001" monitor=serial-monitor
2024-04-23T14:53:16.173Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="received message" error=false event_type=open message=OK monitor=serial-monitor
2024-04-23T14:53:16.173Z daemon INFO time="2024-04-23T09:53:16-05:00" level=info msg="Port /dev/cu.usbserial-0001 successfully opened"
2024-04-23T14:53:16.176Z monitor-service INFO Using port configuration for serial:/dev/cu.usbserial-0001: {"settingsList":[{"settingId":"baudrate","value":"115200"},{"settingId":"bits","value":"8"},{"settingId":"dtr","value":"off"},{"settingId":"parity","value":"none"},{"settingId":"rts","value":"off"},{"settingId":"stop_bits","value":"1"}]}
2024-04-23T14:53:16.176Z monitor-service INFO started monitor to /dev/cu.usbserial-0001 using serial
2024-04-23T14:53:16.243Z monitor-service INFO No port configuration changes have been detected. No need to send configure commands to the running monitor serial:/dev/cu.usbserial-0001.
2024-04-23T14:53:16.244Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-arduino-api@0.1.2 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.551Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(cortex-debug@1.5.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.555Z root INFO [hosted-plugin: 16040] Debugger contribution has been registered: cortex-debug
2024-04-23T14:53:16.567Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-arduino-tools@0.1.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.577Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(cpp@1.52.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.578Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(json@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.579Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(json-language-features@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.593Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-bg@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.596Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-cs@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.597Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-de@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.600Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-es@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.605Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-fr@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.606Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-hu@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.607Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-it@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.608Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-ja@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.609Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-ko@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.609Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-nl@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.609Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-pl@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.610Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-pt-BR@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.610Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-ru@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.610Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-tr@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.612Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-uk@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.617Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-zh-hans@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.618Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): initializing(vscode-language-pack-zh-hant@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-23T14:53:16.666Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-api/extension/dist/extension.js)
2024-04-23T14:53:16.770Z root INFO [hosted-plugin: 16040] calling activation function on Arduino IDE API for VS Code extensions
2024-04-23T14:53:16.788Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain)
2024-04-23T14:53:17.062Z root INFO [hosted-plugin: 16040] calling activation function on JSON Language Features (built-in)
2024-04-23T14:53:17.241Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/extension.js)
2024-04-23T14:53:17.364Z root INFO [hosted-plugin: 16040] calling activation function on VS Code Arduino Tools
2024-04-23T14:53:17.404Z root INFO [aee8d2f0-b6a2-4e3f-bd00-8f3faacc9437] Starting plugins.
2024-04-23T14:53:17.575Z root INFO [hosted-plugin: 16040] PLUGIN_HOST(16040): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js)
2024-04-23T14:53:17.616Z root INFO [hosted-plugin: 16040] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-04-23T14:53:17.618Z root INFO [hosted-plugin: 16040] calling activation function on Cortex-Debug
2024-04-23T14:53:17.628Z root INFO [hosted-plugin: 16040] GDB server console created
2024-04-23T14:53:17.642Z root INFO [aee8d2f0-b6a2-4e3f-bd00-8f3faacc9437] Start of 23 plugins: 7604.5 ms [Finished 20.648 s after frontend start]
2024-04-23T14:53:17.885Z root INFO Starting language server: esp32:esp32:esp32da:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none
2024-04-23T14:53:18.129Z daemon INFO time="2024-04-23T09:53:18-05:00" level=info msg="Adding libraries dir" dir=/Users/danriebs/Library/Arduino15/libraries isSingleLibrary=false location=ide
2024-04-23T14:53:18.129Z daemon INFO time="2024-04-23T09:53:18-05:00" level=info msg="Adding libraries dir" dir=/Users/danriebs/Library/Arduino15/packages/esp32/hardware/esp32/3.0.0-rc1/libraries isSingleLibrary=false location=platform
time="2024-04-23T09:53:18-05:00" level=info msg="Adding libraries dir" dir=/Users/danriebs/Robot/programming/libraries isSingleLibrary=false location=user
2024-04-23T14:53:18.236Z root WARN Widget was activated, but did not accept focus after 2000ms: serial-monitor
2024-04-23T14:53:22.014Z daemon INFO time="2024-04-23T09:53:22-05:00" level=info msg="Resolving include WiFi.h for arch esp32"
2024-04-23T14:53:22.015Z daemon INFO time="2024-04-23T09:53:22-05:00" level=info msg=" found better lib" lib=WiFiNINA prio=517
2024-04-23T14:53:22.015Z daemon INFO time="2024-04-23T09:53:22-05:00" level=info msg=" found better lib" lib=WiFi prio=6B0
2024-04-23T14:53:22.494Z daemon INFO time="2024-04-23T09:53:22-05:00" level=info msg="Resolving include Network.h for arch esp32"
2024-04-23T14:53:22.494Z daemon INFO time="2024-04-23T09:53:22-05:00" level=info msg=" found better lib" lib=Networking prio=64C
2024-04-23T14:53:23.268Z daemon INFO time="2024-04-23T09:53:23-05:00" level=info msg="Resolving include AsyncUDP.h for arch esp32"
2024-04-23T14:53:23.268Z daemon INFO time="2024-04-23T09:53:23-05:00" level=info msg=" found better lib" lib="ESP32 Async UDP" prio=642
2024-04-23T14:53:23.962Z daemon INFO time="2024-04-23T09:53:23-05:00" level=info msg="Resolving include arduino_secrets.h for arch esp32"
2024-04-23T14:53:23.962Z daemon INFO time="2024-04-23T09:53:23-05:00" level=info msg=" found better lib" lib=arduino_secrets prio=6A7
2024-04-23T14:53:34.736Z daemon INFO time="2024-04-23T09:53:34-05:00" level=info msg="Adding libraries dir" dir=/Users/danriebs/Library/Arduino15/libraries isSingleLibrary=false location=ide
2024-04-23T14:53:34.736Z daemon INFO time="2024-04-23T09:53:34-05:00" level=info msg="Adding libraries dir" dir=/Users/danriebs/Library/Arduino15/packages/esp32/hardware/esp32/3.0.0-rc1/libraries isSingleLibrary=false location=platform
time="2024-04-23T09:53:34-05:00" level=info msg="Adding libraries dir" dir=/Users/danriebs/Robot/programming/libraries isSingleLibrary=false location=user
