Hello, I know it is possible to bridge a gsm module with Ethernet using a raspberry pi. I was just curious if it is possible to do the same with an arduino?
The reason I was asking is because I have devices out in the field that only require low bot data to be sending information to the server. Since there is no WiFi or Ethernet in the areas we use GSM. And most of these devices are costly.
I was curious if it is possible to make a bridge between a gsm module and Ethernet?
I would just use the gsm module if that was possible but the device I’m connecting to only has Ethernet it is like a small industrial mini pc.
Joseph
