Hi, I am very new to Arduino and XBEE thus i would like to get some feed back on how to implement this.
Below is an example of the network i plan to implement using arduino and xbee.
Assuming each node as A,B,C,D,E, A is the coordinator. Each of this arduino is connected with a water level sensor & If the water level goes below a certain level it triggers to refill the tank to the required level. I managed to get to this part working, however because im not very familiar with xbee i want to know how i can implement the following.
Can the Coordinator trigger to make all the node's refill?
What library should i use if i want to control the coordinator via internet?
If node B detects that the water level is low, I want trigger the alarm for the neighboring node, meaning trigger the alarm for C but not D & E
(This is the part where i am confused, is it possible for the xbee to work in send and receive mode simultaneously? If so how can i achieve it? Should all the nodes be working in router mode???)
Any help is appreciated.
Yes.
Yes. Well, not exactly simultaneously, but a single XBee can intermix transmissions and receptions arbitrarily with no problem.
I would use XBee ZB modules (f.k.a. Series 2), API mode, and this library:
No. The ZB modules require one and only one coordinator in a network. The rest can be routers. A coordinator can do everything a router can.
HINT: Start small. Don't try to eat this elephant in a single bite. One step at a time.
