Arduino YUN failed update
hi, i tried to update my YUN (rev1) and no it doesnt boot the linux. I can connect via usb but can´t via netwrork tft etc. so I can't downdrade the firmware as arduino.cc sugest.
Either can't enter the u-boot interface with the correct prompt "root@xxxx.local:" typing "ARD" while booting only get prompt "arduino:"
this is the complete boot log
Any ideas what can I do? Please!
U-Boot 1.1.5-linino-g2d891225 (Nov 22 2017 - 09:06:12)
Linino Board (ar9331) U-boot
DRAM: 64 MB
Top of RAM usable for U-Boot at: 84000000
Reserving 218k for U-Boot at: 83fc8000
Reserving 192k for malloc() at: 83f98000
Reserving 44 Bytes for Board Info at: 83f97fd4
Reserving 36 Bytes for Global Data at: 83f97fb0
Reserving 128k for boot params() at: 83f77fb0
Stack Pointer at: 83f77f98
Now running in RAM - U-Boot at: 83fc8000
Flash Manuf Id 0xef, DeviceId0 0x40, DeviceId1 0x18
flash size 16777216, sector count = 256
Flash: 16 MB
In: serial
Out: serial
Err: serial
Net: eth0: 00:03:7f:11:40:00
eth1: 00:03:7f:11:40:01
eth0, eth1
autoboot in 4 seconds (stop with 'ard')...
Booting image at 9f050000 ...
Bad Magic Number
Booting image at 9fea0000 ...
Image Name: MIPS OpenWrt Linux-3.3.8
Created: 2015-10-04 0:29:52 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 1089561 Bytes = 1 MB
Load Address: 80060000
Entry Point: 80060000
Verifying Checksum at 0x9fea0040 ...OK
Uncompressing Kernel Image ... OK
No initrd
Transferring control to Linux (at address 80060000) ...
Giving linux memsize in bytes, 67108864
Starting kernel ...
[ 0.000000] Linux version 3.3.8 (build@build-base) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Sun Oct 4 02:29:26 CEST 2015
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] User-defined physical RAM map:
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00004000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00004000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: board=Yun console=ttyATH0,250000 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env),15936k(firmware),64k(nvram),64k(art)ro rootfstype=squashfs,jffs2 noinitrd mem=64M rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] MIPS: no machine found for id 'Yun', supported machines:
[ 0.000000] id name
[ 0.000000] Generic Generic AR71XX/AR724X/AR913X based board
[ 0.000000] linino-yun-mini Arduino Yun-Mini
[ 0.000000] linino-one Linino One
[ 0.000000] linino-yun Arduino Yun
[ 0.000000] linino-freedog Linino Freedog
[ 0.000000] linino-lei Linino Lei
[ 0.000000] linino-chiwawa Linino Chiwawa
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 61144k/65536k available (2358k kernel code, 4392k reserved, 642k data, 180k init, 0k highmem)
[ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:256
[ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.080000] NET: Registered protocol family 16
[ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
[ 0.090000] MIPS: machine is Generic AR71XX/AR724X/AR913X based board
[ 0.100000] bio: create slab at 0
[ 0.110000] Switching to clocksource MIPS
[ 0.120000] NET: Registered protocol family 2
[ 0.120000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.120000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.120000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.120000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.120000] TCP reno registered
[ 0.120000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.130000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.130000] NET: Registered protocol family 1
[ 0.150000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.150000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.160000] msgmni has been set to 119
[ 0.160000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.160000] io scheduler noop registered
[ 0.170000] io scheduler deadline registered (default)
[ 0.170000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.180000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) i{ a AR933X UART
[ 0.180000] console [ttyATH0] enabled, bootconsole disabled
[ 0.200000] TCP cubic registered
[ 0.200000] NET: Registered protocol family 17
[ 0.200000] Bridge firewalling registered
[ 0.200000] 8021q: 802.1Q VLAN Support v1.8
[ 0.210000] VFS: Cannot open root device "(null)" or unknown-block(0,0)
[ 0.210000] Please append a correct "root=" boot option; here are the available partitions:
[ 0.210000] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
DRAM: 64 MB
Flash: 16 MB
In: serial
Out: serial
Err: serial
eth0, eth1
arduino> bdinfo
boot_params = 0x83F77FB0
memstart = 0x80000000
memsize = 0x04000000
flashstart = 0x9F000000
flashsize = 0x01000000
Since you have entered the Arduino U-Boot prompt, you can flash the latest OpenWrt image using a TFTP server. Launch your TFTP server and ensure it binds to the 192.168.10.1 network interface. Place the two files downloaded from the OpenWrt website (initramfs-kernel and squashfs-sysupgrade) into your TFTP root directory.
setenv serverip 192.168.10.1
setenv ipaddr 192.168.10.2
tftp 0x80060000 openwrt-25.12.4-ath79-generic-arduino_yun-kernel.bin
erase 0x9fea0000 +0x140000
cp.b 0x80060000 0x9fea0000 0x140000
tftp 0x80060000 openwrt-25.12.4-ath79-generic-arduino_yun-rootfs.bin
erase 0x9f050000 +0xe50000
cp.b 0x80060000 0x9f050000 0xe50000
bootm 0x9fea0000
You are done.
Could you please share your ART partition backup later? I accidentally lost mine.
