I am using this code
// Setup TCC0 to capture pulse-width and period on D6
volatile boolean periodComplete;
volatile uint32_t isrPeriod;
volatile uint32_t isrPulsewidth;
uint32_t period;
uint32_t pulsewidth;
Serial.begin(115200); // Configure the native USB port
while(!Serial); // Wait for the console to be ready
Serial.print("asd");
PM->APBCMASK.reg |= PM_APBCMASK_EVSYS; // Switch on the event system peripheral
GCLK->GENDIV.reg = GCLK_GENDIV_DIV(1) | // Divide the 48MHz system clock by 3 = 16MHz
GCLK_GENDIV_ID(4); // Set division on Generic Clock Generator (GCLK) 5
GCLK->GENCTRL.reg = GCLK_GENCTRL_IDC | // Set the duty cycle to 50/50 HIGH/LOW
GCLK_GENCTRL_GENEN | // Enable GCLK 4
GCLK_GENCTRL_SRC_DFLL48M | // Set the clock source to 48MHz
GCLK_GENCTRL_ID(4); // Set clock source on GCLK 4
while (GCLK->STATUS.bit.SYNCBUSY); // Wait for synchronization
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_CLKEN | // Route GCLK4 to TCC0 and TCC1
GCLK_CLKCTRL_GEN_GCLK4 |
GCLK_CLKCTRL_ID_TCC0_TCC1;
// Enable the port multiplexer on digital pin D6
PORT->Group[PORTA].PINCFG[20].bit.PMUXEN = 1;
// Set-up the pin as an EIC (interrupt) peripheral on D6
PORT->Group[PORTA].PMUX[20 >> 1].reg |= PORT_PMUX_PMUXE_A;
EIC->EVCTRL.reg |= EIC_EVCTRL_EXTINTEO4; // Enable event output on external interrupt 4
EIC->CONFIG[0].reg |= EIC_CONFIG_SENSE4_HIGH; // Set event detecting a HIGH level
EIC->INTENCLR.reg = EIC_INTENCLR_EXTINT4; // Clear the interrupt flag on channel 4
EIC->CTRL.reg |= EIC_CTRL_ENABLE; // Enable EIC peripheral
while (EIC->STATUS.bit.SYNCBUSY); // Wait for synchronization
EVSYS->USER.reg = EVSYS_USER_CHANNEL(1) | // Attach the event user (receiver) to channel 0 (n + 1)
EVSYS_USER_USER(EVSYS_ID_USER_TCC0_EV_1); // Set the event user (receiver) as timer TCC0, event 1
EVSYS->CHANNEL.reg = EVSYS_CHANNEL_EDGSEL_NO_EVT_OUTPUT | // No event edge detection
EVSYS_CHANNEL_PATH_ASYNCHRONOUS | // Set event path as asynchronous
EVSYS_CHANNEL_EVGEN(EVSYS_ID_GEN_EIC_EXTINT_4) | // Set event generator (sender) as external interrupt 4
EVSYS_CHANNEL_CHANNEL(0); // Attach the generator (sender) to channel 0
TCC0->EVCTRL.reg |= TCC_EVCTRL_MCEI1 | // Enable the match or capture channel 1 event input
TCC_EVCTRL_MCEI0 | //.Enable the match or capture channel 0 event input
TCC_EVCTRL_TCEI1 | // Enable the TCC event 1 input
/*TCC_EVCTRL_TCINV1 |*/ // Invert the event 1 input
TCC_EVCTRL_EVACT1_PPW; // Set up the timer for capture: CC0 period, CC1 pulsewidth
NVIC_SetPriority(TCC0_IRQn, 0); // Set the Nested Vector Interrupt Controller (NVIC) priority for TCC0 to 0 (highest)
NVIC_EnableIRQ(TCC0_IRQn); // Connect the TCC0 timer to the Nested Vector Interrupt Controller (NVIC)
TCC0->INTENSET.reg = TCC_INTENSET_MC1 | // Enable compare channel 1 (CC1) interrupts
TCC_INTENSET_MC0; // Enable compare channel 0 (CC0) interrupts
TCC0->CTRLA.reg |= TCC_CTRLA_CPTEN1 | // Enable capture on CC1
TCC_CTRLA_CPTEN0 | // Enable capture on CC0
TCC_CTRLA_PRESCSYNC_PRESC | // Reload timer on the next prescaler clock
TCC_CTRLA_PRESCALER_DIV16; // Set prescaler to 16, 16MHz/16 = 1MHz
TCC0->CTRLA.bit.ENABLE = 1; // Enable TCC0
while (TCC0->SYNCBUSY.bit.ENABLE); // Wait for synchronization
if (periodComplete) // Check if the period is complete
period = isrPeriod;
Serial.println(period/3);
periodComplete = false; // Start a new period
void TCC0_Handler() // Interrupt Service Routine (ISR) for timer TCC0
// Check for match counter 0 (MC0) interrupt
if (TCC0->INTFLAG.bit.MC0)
isrPeriod = TCC0->CC[0].reg; // Copy the period
periodComplete = true; // Indicate that the period is complete
// Check for match counter 1 (MC1) interrupt
if (TCC0->INTFLAG.bit.MC1)
isrPulsewidth = TCC0->CC[1].reg; // Copy the pulse-width
to measure the pulse width of a 1 PPS (pulse per second) signal from a GPS module. Those signals are extremely accurately 1 Hz (period deviations of a few ns). But my code produces varying pulse lengths with variations of about 10+ us with a constant offset of about 100 us. I can deal with the offset but the jitter (random variations) of the measured length are a problem.
Here is a sample of the output:
Is this behavior to be expected? I thought that with a 48MHz controller and input capture interrupts I would get accuracy below 1 us. Are there problems with my code?
Thank you very much for any input in advance!
