Hi all,
I'm using an Arduino MKR WiFi 1010 board. When I try out the Simple RTC sketch from the RTC Zero library, the RTC keeps time pretty well. Maybe loses or gains a second or two per day. Note, the Simple RTC sketch has to be manually initialised with time and date, and does not connect to wifi or sync with a NTP server. It's totally dependent on the SAMD RTC function and the clock source feeding it. So there can't be too much wrong with the underlying hardware and framework of the MKR 1010 RTC.
But when I call the ArduinoCloud.getLocalTime() function repeatedly (in a different sketch), the returned time gradually drifts (runs slow) by a minute or so per hour.
Is there some sort of restriction or requirement that I'm not aware of regarding how to call the ArduinoCloud.getLocalTime() function in order to get accurate time?
I'm aware that I can set TimeService.setSyncInterval(xxx) to force a frequent sync with an NTP server if I need more accurate time. But why is the time so badly inaccurate in the first place?
I thought I had read on this forum that the ArduinoCloud.getLocalTime() function uses the RTC Zero library, so there doesn't seem to be any reason why the time should not be much more accurate than it is.
You can see from the serial output I've attached that the function loses about 5 sec or so every time I call it, 5 minutes apart. Surely this can't be expected behaviour?
Any suggestions? Sketch and output below Thanks.
#include "arduino_secrets.h"
#include "thingProperties.h"
#include <U8x8lib.h>
#include <TimeLib.h>
#define TIMELOOPTIME 300000
tmElements_t timeStructure;
U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(/* reset=*/ U8X8_PIN_NONE);
bool toggle;
int timeLoopTimer;
unsigned long UnixTime;
digitalWrite(LED_BUILTIN, HIGH);
delay(1500);
u8x8.begin();
u8x8.setFont(u8x8_font_courB18_2x3_f);
initProperties();
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(4);
ArduinoCloud.printDebugInfo();
while(ArduinoCloud.getLocalTime() == 0){
ArduinoCloud.update();
digitalWrite(LED_BUILTIN, LOW);
timeLoopTimer = 200000;
if ((millis() - timeLoopTimer) > TIMELOOPTIME){
timeLoopTimer = millis();
UnixTime = ArduinoCloud.getLocalTime();
breakTime(UnixTime, timeStructure); // breakTime breaks Unix seconds into HH, MM, SS etc.
toggle = !toggle;
digitalWrite (LED_BUILTIN, toggle);
u8x8.clearDisplay();
u8x8.setCursor(0, 3);
Serial.print("Unix Time: ");
Serial.println(UnixTime);
u8x8.print(timeStructure.Hour);
Serial.print("timeStructure.Hour: ");
Serial.println(timeStructure.Hour);
u8x8.setCursor(6, 3);
u8x8.print(timeStructure.Minute);
Serial.print("timeStructure.Minute: ");
Serial.println(timeStructure.Minute);
u8x8.setCursor(12, 3);
u8x8.print(timeStructure.Second);
Serial.print("timeStructure.Second: ");
Serial.println(timeStructure.Second);
Serial output:
14:45:24.489 -> Unix Time: 1720968324
14:45:24.489 -> timeStructure.Hour: 14
14:45:24.489 -> timeStructure.Minute: 45
14:45:24.489 -> timeStructure.Second: 24
14:50:24.448 -> Unix Time: 1720968617
14:50:24.487 -> timeStructure.Hour: 14
14:50:24.487 -> timeStructure.Minute: 50
14:50:24.487 -> timeStructure.Second: 17
14:55:24.496 -> Unix Time: 1720968911
14:55:24.496 -> timeStructure.Hour: 14
14:55:24.496 -> timeStructure.Minute: 55
14:55:24.542 -> timeStructure.Second: 11
15:00:24.594 -> Unix Time: 1720969204
15:00:24.594 -> timeStructure.Hour: 15
15:00:24.594 -> timeStructure.Minute: 0
15:00:24.594 -> timeStructure.Second: 4
15:05:24.669 -> Unix Time: 1720969498
15:05:24.669 -> timeStructure.Hour: 15
15:05:24.669 -> timeStructure.Minute: 4
15:05:24.669 -> timeStructure.Second: 58
15:10:24.683 -> Unix Time: 1720969791
15:10:24.683 -> timeStructure.Hour: 15
15:10:24.683 -> timeStructure.Minute: 9
15:10:24.683 -> timeStructure.Second: 51
