(ArduinoJson) crash trying to pass JsonObject
I think this is probably a generic question about my misunderstanding of references, but it's specifically come up while using the ArduinoJson library.
I got my program succesfully reading JSON from an external source, using the ArduinoJson library to parse it, converting data into the form I need it, and so on.
Having got it roughly working, I then started cleaning it up and moved a bit of code into a function so that I could call it in two places.
The critical piece is a loop over a JsonArray. Originally it was inline in the function that had parsed the JSON data, i.e. (omitting various error checking):
 	float fWidth;
  	DeserializationError error = deserializeJson(doc, jsonText);
	JsonArray aDims = doc["dimensionsList"].as<JsonArray>();
 	for (JsonObject repo : aDims) {
 	 	fWidth = repo["width"];
 	 	Serial.println(fWidth);
... which works fine.
Then I attempted to move the processing of the elements of the array into a function, and it crashes as soon as it tries to access one of the elements of the JsonObject:
 	 	printWidth(repo);
void printWidth(JsonObject jElement)
 	float fWidth;
	fWidth = jElement["width"];		// crashes on this line
Evidently there is an issue with how I pass the iterator JsonObject into the function - or how I then access the elements of it.
I've read @BenoitB's excellent book, with the very helpful "missing C++ course" chapter; but I didn't see anything which would suggest that this shouldn't work. I've also in desperation tried all the variations of syntax I could imagine, but none worked. I also, since (in the actual code as opposed to the above cut-down one) the secondary function doesn't need to change the values in the JsonObject, tried declaring it as const in the secondary function; no joy.
I don't see why it wouldn't be possible to pass a reference into a function, and then use it in this way... am I wrong? And if not, what am I doing wrong in this syntax?
What happens when you pass the object by reference?
void printWidth(JsonObject& jElement)
Still crash, alas.
what if you do
 	for (JsonObject&& repo : aDims) {
 	 	printWidth(repo);
and define the function with a reference
void printWidth(JsonObject& jElement) {
   	float fWidth = jElement["width"];
What does this && syntax
do?
Surely I can't change what the iteration over aDims consists of?
It is an Universal/Forwarding Reference.
We usually actually would let the compiler figure things out and write
for (auto && repo : aDims) {
 	 	printWidth(repo);
(You could also use only one & probably here.)
The point is that you don’t get a copy of the item accessed by the array notation but a reference to it. Just wondering if that would make any difference
Hi @KellyLH,
The program you shared in your original message should work just fine.
Here is an online demo to prove there is nothing wrong with it: [C++] gcc 4.9.4 - Wandbox
The problem lies probably in the parts you omitted.
Please provide an MCVE.
BTW, thank you very much for purchasing my book :heart:
Best regards,
Benoit
Hi @BenoitB - I'm an idiot! Thank you.
Indeed, I am afraid I cut down the example in my post, rather than in my code; and as you say, there was in fact no problem with passing the JsonObject in that way. The crashing problem was (and is, I am still banging my head against the wall) in what I thought was a perfectly straightforward bit of syntax that was part of the same refactoring. I took it for granted that the problem was in the exotic new syntax that I didn't really understand.
Apologies for wasting your time. Thanks again for the ArduinoJson library, and the book - both are excellent.
Many thanks,
Kelly.
