ArduinoJson save/load variable to config.json individually (ver 5 or 6)
Hi there,
I am building a relatively simple solution to save variables/values to spiffs via arduinojson.
In nutshell:
The default variables/values are saved to config.json file while the esp8266 in function, though web interface. The next reboot the new variables, like ssid/password are loaded, and connection estabilished. Still i have pleanty of other variables as well, the explanations yet is just for simplicity with ssid/pass.
The default configuration-save/load are working good, but the save for only one variable to conf.json are overwriting the file, so i get the file just with the variable=value which has been saved lastly.
Can someone point me, or hint or help..how to get this part of the code working as expected:
If variable exists, then update the new value, if not, then create and save.
At the moment the code has been built with arduinojson 5, i dont mind if we need to update to 6.
Thank in advance,
void ConfigFile_Save_Variable(String text, String value) {
  Serial.print("Save_VariableToConfigFile: ");
  Serial.print(text); Serial.print("="); Serial.print(value);
  File configFile = SPIFFS.open("/config.json", "w");
  if (!configFile) {
    Serial.println("- failed to open config file for writing");
    return;
  DynamicJsonBuffer jsonBuffer;
  JsonObject& json = jsonBuffer.createObject();
  json[text] = value;
  //json.printTo(Serial);                    //print to - serial - debug
  json.printTo(configFile);                 //print to - file
  configFile.close();
  Serial.println("");
  Serial.println(" - config.json saved - OK.");
Meanwhile,
it seems I have figured it out. had to use an open-write loop with file in the same function.
Updated to arduinojson 6.
void ConfigFile_Save_Variable(String VarName, String VarValue) {
  Serial.print("ConfigFile_Save_Variable: ");
  Serial.print(VarName); Serial.print("="); Serial.print(VarValue);
  File configFile = SPIFFS.open("/config.json", "r");
  if (!configFile) {
    return;
  DynamicJsonDocument doc(2048);
  deserializeJson(doc, configFile);
  serializeJson(doc, Serial);
  configFile.close();
  doc[VarName] = VarValue;
  configFile.close();
  Serial.println("");
