Apple Mac OS
Firefox 122.0
Arduino IDE 2.2.1
Arduino Nano WiFi
ESP32-Server
Arduino C++
TCP-IP
I downloaded ArduinoWebSockets/ESP32-Server to serve as a beginning websocket server. (I got it from the Examples.) Having pasted it into a sketch, I tried compiling it. Of course it wouldn't, but the thing I'm having the most trouble with is: It's all pre-compile instructions with no actual code. At present the compiler is complaining about lack of both setup() and loop() routines.
Is there supposed to be any code with this? Are there any complete websocket server sketches available for ESP32?
// ArduinoWebSockets/ESP32-Server
// Standard iostream objects -*- C++ -*-
// Copyright (C) 1997-2024 Free Software Foundation, Inc.
// This file is part of the GNU ISO C++ Library. This library is free
// software; you can redistribute it and/or modify it under the
// terms of the GNU General Public License as published by the
// Free Software Foundation; either version 3, or (at your option)
// any later version.
// This library is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// Under Section 7 of GPL version 3, you are granted additional
// permissions described in the GCC Runtime Library Exception, version
// 3.1, as published by the Free Software Foundation.
// You should have received a copy of the GNU General Public License and
// a copy of the GCC Runtime Library Exception along with this program;
// see the files COPYING3 and COPYING.RUNTIME respectively. If not, see
// <http://www.gnu.org/licenses/>.
/** @file include/iostream
* This is a Standard C++ Library header.
// ISO C++ 14882: 27.3 Standard iostream objects
#ifndef _GLIBCXX_IOSTREAM
#define _GLIBCXX_IOSTREAM 1
#pragma GCC system_header
#include <ArduinoWebsockets.h>
//#include <bits/requires_hosted.h> // iostreams
#include <bits/c++config.h>
#include <ostream>
#include <istream>
namespace std _GLIBCXX_VISIBILITY(default)
_GLIBCXX_BEGIN_NAMESPACE_VERSION
* @name Standard Stream Objects
* The `<iostream>` header declares the eight *standard stream objects*.
* For other declarations, see
* http://gcc.gnu.org/onlinedocs/libstdc++/manual/io.html
* and the @link iosfwd I/O forward declarations @endlink
* They are required by default to cooperate with the global C
* library's `FILE` streams, and to be available during program
* startup and termination. For more information, see the section of the
* manual linked to above.
extern istream cin; ///< Linked to standard input
extern ostream cout; ///< Linked to standard output
extern ostream cerr; ///< Linked to standard error (unbuffered)
extern ostream clog; ///< Linked to standard error (buffered)
#ifdef _GLIBCXX_USE_WCHAR_T
extern wistream wcin; ///< Linked to standard input
extern wostream wcout; ///< Linked to standard output
extern wostream wcerr; ///< Linked to standard error (unbuffered)
extern wostream wclog; ///< Linked to standard error (buffered)
#endif
// For construction of filebuffers for cout, cin, cerr, clog et. al.
// When the init_priority attribute is usable, we do this initialization
// in the compiled library instead (src/c++98/globals_io.cc).
#if !(_GLIBCXX_USE_INIT_PRIORITY_ATTRIBUTE \
&& __has_attribute(__init_priority__))
static ios_base::Init __ioinit;
#elif defined(_GLIBCXX_SYMVER_GNU)
__extension__ __asm (".globl _ZSt21ios_base_library_initv");
#endif
_GLIBCXX_END_NAMESPACE_VERSION
} // namespace
#endif /* _GLIBCXX_IOSTREAM */
