Arduno DMX shield to Modul8 or Qlab
Hi, I've allready made a dmx shield working.I've connected 4 led pars, who are programmed to listen from channel 1-16 for each par 4 channels. I have tested the DMXsimple library, but I want to know how to connect the shield to Modul8 or Qlab? I have the the shield connected to digital-in 1. How do I have to program the DMX shield to understand the Enttec USB PRO drivers to work in OSX?
As far as I understand you can use this tutorial to realize it:
http://blog.wingedvictorydesign.com/2009/03/20/receive-dmx-512-with-an-arduino/all/1/
And i've seen this:
http://www.arduino.cc/playground/DMX/Opendmx
But how do i have to program my Arduino. Do i have to put an empty script on it?
But which steps do i have to undertake to get the openDMX usb drivers to detect the shield in OSX?
Thanks in advance :wink:
Solved it by making a Arduno DMX > serial > midi connection:
First i've installed:
http://projectgus.github.com/hairless-midiserial/
and combined the ardumidi and dmx simple library like this:
/* Welcome to DmxSimple. This library allows you to control DMX stage and
 ** architectural lighting and visual effects easily from Arduino. DmxSimple
 ** is compatible with the Tinker.it! DMX shield and all known DIY Arduino
 ** DMX control circuits.
 ** DmxSimple is available from: http://code.google.com/p/tinkerit/
 ** Help and support: http://groups.google.com/group/dmxsimple       */
/* To use DmxSimple, you will need the following line. Arduino will
 ** auto-insert it if you select Sketch > Import Library > DmxSimple. */
#include <DmxSimple.h>
#include <ardumidi.h>
int ledPin = 13;
int note_on = 0;
  /* The most common pin for DMX output is pin 3, which DmxSimple
   ** uses by default. If you need to change that, do it here. */
  DmxSimple.usePin(11);
  Serial.begin(115200); // will change baud rate of MIDI traffic from 31250 to 115200
  /* DMX devices typically need to receive a complete set of channels
   ** even if you only need to adjust the first channel. You can
   ** easily change the number of channels sent here. If you don't
   ** do this, DmxSimple will set the maximum channel number to the
   ** highest channel you DmxSimple.write() to. */
  DmxSimple.maxChannel(256);
int value = 0;
int channel;
  while (midi_message_available() > 0) {
    // DmxSimple.write(3, 255);
    MidiMessage m = read_midi_message();
    int controlMax = 127;
    int c = int(m.channel)+1;
    int channel = m.channel+1;
    int control = m.param1;
    int controlSelect = m.param1;
    if (channel == 1){  //
      while ( (channel   == 1) && (control == control)  )  { // BLEND
        int velocity =   map(int(m.param2),0,127,0,255);
        DmxSimple.write(control, velocity);
    else if (channel == 2) {
      while ( (channel == 2) && (control == control)  )  { // BLEND
        DmxSimple.write(controlMax+control, velocity);
    // reset all channels after use
        if (channel == 3){
      while ( (channel   == 1) && (control == control)  )  { // seperate
        reset(int(control));
    else if (channel == 4) {
      while ( (channel == 2) && (control == control)  )  { // seperate
        reset(int(controlMax+control));
    // STOP ALL CHANNELS
    if( (channel == 16) && (control ==  1)){ // STOP
      for(int i=0; i< 512; i++){
        DmxSimple.write(i, 0);
void reset(int noChannel){
    for(int i=0; i< 256; i++){
      if (noChannel == i){
For people, who don't like latency on the FTDI driver, look at this:
http://projectgus.com/2011/10/notes-on-ftdi-latency-with-arduino/
