I have been using the following macro to more conveniently format my Serial.print commands, but soon also to change the destination of where the text goes instead of Serial. As I understand it, when compiling, the code in the define replaces spots where I say PRINT(...). With how long these are getting, and each one might get longer, could this be using more processing time/memory than just making a VOID function?
// Debugging switches and macros
#define DEBUG 4 // Switch debug output on and off by 1+ or 0
#define wLine 1 // Set 0 to include printing the line number
#define DEBUGS 0 // Switch Spamming debug output on and off by 1+ or 0
#define TIMELOG 0 // Switch debug output on and off by 1 or 0
#define WIFI 0 //Set to 0 if you want to avoid the wifi check
#if DEBUG //For all debugs
#if wLine
#define PRINTS(s) \
Serial.print(F(s)); \
Serial.print(" @ Line "); \
Serial.print(__LINE__); \
Serial.println(); \
#define PRINT(s, v) \
Serial.print(": "); \
Serial.print(v); \
Serial.println(); \
#define PRINTX(s, v) \
Serial.print(F("0x")); \
Serial.print(v, HEX); \
Serial.println(); \
#else
#define PRINTS(s) \
Serial.println(); \
Serial.print(v); \
Serial.println(); \
Serial.println(); \
#endif
#else
#define PRINTS(s)
#define PRINT(s, v)
#endif
With UNO, you can easily run out of ram... so keep that in mind...
With esp a bit of text is usually not the problem... things like .png files might get you into trouble though...
Not more time really as in case of a function or duplicated code, you still spend the time doing what needs to be done. The function call will actually add one extra indirection compared to the inlined version so will be (imperceptibly) slower.
The size of the binary will shrink significantly if you use a function which would use the macro but all this is caught and reported by the compiler so you would know if you run out of flash memory.
One challenges going with the function is going to be the text that your macro works on as F(s). You’ll need to have that F() call inside the function’s parameters otherwise you’ll eat up RAM (and of course the F() stuff won’t work in the function anyway), and you’ll have to cast as a flash based address.
Long story short - if the compiler doesn’t say you are running out of flash memory you are fine (for the time being).
Side note:
You could save one call in your macro by removing the last println() and embed that into
Your use of brackets isn't quite right, and there's room for optimization:
#define xstr(s) #s
#define STRINGIFY(n) xstr(n)
do { \
Serial.print(F(s ": 0x")); \
Serial.println(F("@ Line " STRINGIFY(__LINE__))); \
} while (0)
(The compiler will automatically concatenate adjacent literal strings, so "foo" " bar" is exactly the same as "foo bar"
The STRINGIFY/xstr stuff is "standard mysterious preprocessor stuff" for turning a compile-time numeric constant into a literal string.)
