Are the Arduino family of Chips Pin compatible? I mean, could you simply unplug one chip and upgrade to the better one if you purchased the lowend board first? Rightnow , I have the Mega. I wanted to purchase a few more boards. But, what if they are not as fast as I want them, do I have to buy all new boards or just the chips?
In short no. Some have the same pin out as other but the mega is a quad flat package and the 168 and 328 are DIL (these are the same)
See the data sheet
Well I have interchanged the following 28 pin DIP AVR chips in a Arduino clone board, meg8, mega168, mega328. All worked well and I was able to reburn bootloaders for all three using a USBtiny programmer and the ISP connection on the Arduino board using AVRDUDE. So either blank chips or chips with pre-burned arduino bootloaders can work fine. Just be sure to change the board selection in the Arduino IDE before compiling or downloading a new sketch.
Lefty
As far as I am aware these all run at 16MHz anyway so there will be no speed advantage.
Thanks for the info.
