Hello,
So while working on an array that can store multiple numbers, I came across a strange error I have not seen before.
In the image attached you will see the problem.
I would like to know how the serial read changes my 1,100 into a B, since I cannot find anything relate able on the interwebs that I can use as reference.
Can someone please give me a few pointers or explain to me where I screwed up with the code?
Thank you in advance!
char coupeNumberChar[4];
char numberOfPeopleChar[4];
int ByteReceived;
bool checkingCoupeNumber = true;
int counter = 0;
if (Serial.available() > 0)
checkingCoupeNumber = false;
while (Serial.available() > 0) {
Serial.println("reading");
ByteReceived = Serial.read();
delay(50);
if (ByteReceived == '#') {
else if (ByteReceived == '%') {
return;
else if (checkingCoupeNumber && ByteReceived != ',') {
coupeNumberChar[counter] += ByteReceived;
Serial.print("recieved char: ");
Serial.println(coupeNumberChar[counter]);
counter++;
else if (ByteReceived == ',') {
coupeNumberChar[counter] = '\0';
counter = 0;
else if (!checkingCoupeNumber) {
numberOfPeopleChar[counter] += ByteReceived;
Serial.println(numberOfPeopleChar[counter]);
counter++;
numberOfPeopleChar[counter] = '\0';
counter = 0;
for (int i = 0; i < 3; i++) {
Serial.print(coupeNumberChar[i]);
Serial.print(", ");
Serial.println("");
Serial.print(numberOfPeopleChar[i]);
Serial.print(", ");
Serial.println("");
int coupeNumber = atoi(coupeNumberChar);
Serial.println(coupeNumber);
int numberOfPeople = atoi(numberOfPeopleChar);
Serial.println(numberOfPeople);
memset(coupeNumberChar, 0, sizeof(coupeNumberChar));
memset(numberOfPeopleChar, 0, sizeof(numberOfPeopleChar));
Edit: I think personally that the error happens with the memset(); function, so I'll be checking out if changing that will fix the problem (or at least clarify the number to letter bug)
Edit 2: After making some changes in the code I discovered that the memset (the function that sets the values to 0) is no the culprit, but rather the atoi();
