Why cant I assign one array to another array?
int array1[] = {1,2,3,4};
int array2[4];
array2 = array1;
int array2[4];
array2 = array1;
C-style arrays are exceptions to many rules in C++. If you can (i.e. on any board except AVR), use C++ arrays:
#include <array>
std::array<int, 4> array1 = {1,2,3,4};
std::array<int, 4> array2;
array2 = array1;
void loop() {}
If you're stuck on AVR, you'll have to copy the elements manually using a for loop, or if they are trivially copyable types such as int, you can use memcpy.
It might be worth considering whether you actually need to copy anything. It might be more efficient to keep a pointer to the array and simply change the pointer to point to another array instead of copying all elements in the array.
Pieter
Because the way that you are doing it is not valid in C/C++
One way to do it is with memcpy()
int array1[] = {1, 2, 3, 4};
int array2[4];
memcpy(array2, array1, sizeof(array1));
for (int x = 0; x < 4; x++)
Serial.println(array2[x]);
