Arrays, Interrupts and Millis()
I'm trying to record the times of each input to an interrupt, and regularly process the results, resetting the data. I am using two arrays, one of which is used to record the data, the other becomes a copy of the first before processing the data.
The arrays are supposed to hold the millis() at the time of the input.
Unfortunately, when I analyse the data, the arrays appear to be empty.
Where did I go wrong?
volatile unsigned long buttonPushes[133];
unsigned long calcPushes[133];
const byte interruptPin = 2;
volatile int buttonPushCount = 0 ;
int calcCount = 0;
  pinMode(interruptPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin), buttonPush, FALLING);
  buttonPushes[buttonPushCount] = millis();
  delay(10000);  // period between analysis
  calcCount = 0;
  while (calcCount < buttonPushCount) {
    calcPushes[calcCount] = buttonPushes[calcCount];
    calcCount++;
  buttonPushCount = 0;
  if (calcCount == 0) {buttonPushes[0] = millis();}
  else buttonPushes[buttonPushCount] = calcPushes[calcCount];
Serial.print("calcCount = ");
Serial.println(calcCount);
Serial.print("Total time between start and last push: ");
Serial.println((calcPushes[calcCount] - calcPushes[0]));
Serial.print("Time of last button push: ");
Serial.println(calcPushes[calcCount]);
void buttonPush() {
  buttonPushCount++;
The value is undefined here.
That's just there so that if there had been no activity in the previous time period, the start time is set to the current time, and if there had been activity in the previous period, the time of the last input is passed to the start of the new period. The value passed in the "else" option is the time of the last input.
That's your intention but not your code. You reference an array cell that was not initialized before.
Thank you for that. I've changed these:
volatile unsigned long buttonPushes[133] = {};
unsigned long calcPushes[133] = {};
and I'm now getting some numbers. I assume that's what you meant, so I'll set up some calculations with the results to see if they make any sense.
this whole section should be protected..
the volatile vars are multi byte, and can change while your in the loop..
language/variables/variable-scope-qualifiers/volatile/
need to disable interrupts then turn them back on just after..
good luck.. ~q
Thanks for pointing this out, much appreciated.
Which Arduino board ?
perhaps start with a simpler example, e.g.
// UNO- Measure time between two button presses
// constants button 1 and 2 pins
const int buttonOnePin = 2;
const int buttonTwoPin = 3;
// volatile variables for hold button press times
volatile long button1timer = 0, button2timer = 0;
// interrupt routines for button 1 and 2 - note time pressed
void buttonOnePressed(void) {
  button1timer = millis();
void buttonTwoPressed(void) {
  button2timer = millis();
  // start Serial
  Serial.println("measure time between button presses");
  pinMode(buttonOnePin, INPUT);
  pinMode(buttonTwoPin, INPUT);
  // set up the interrupts
  attachInterrupt(digitalPinToInterrupt(buttonOnePin), buttonOnePressed, FALLING);
  attachInterrupt(digitalPinToInterrupt(buttonTwoPin), buttonTwoPressed, FALLING);
  if (button2timer) {   // if button 2 pressed display time interval
    Serial.print("button 2 - button 1 time ");
    Serial.print((button2timer - button1timer) / 1000.0f);
    Serial.println(" seconds");
    button2timer = 0;   // clear button 2 timer ready for next measurement
serial monitor output
button 2 - button 1 time 1.50 seconds
button 2 - button 1 time 3.36 seconds
button 2 - button 1 time 8.14 seconds
No. calcPushes[calcCount] is undefined.
I'm not seeing where or how you make sure not to gather more than 133 samples.
What is making the interrupts? What is the significance of the dimension 133? Is it possible you are getting more than 133 interrupts in your sample window?
Just now that is the only way I can interpret @DrDiettrich's several warnings about the undefined variable.
Your fix in #5 changes nothing; global variables are initially zero, so changing out
for
cannot explain any new success.
a7
Have a look at the loop
After that loop calcCount is 1 higher than the last copied entry. And just that undefinied entry is used a few lines later:
The else part suffers from 2 issues:
  • buttonPushCount is and should be zero, a variable is dangerous here.
  • calcCount points 1 past the last copied value
OK, but it's not undefined, it has just not been assigned a value during this sample window.
On the other hand, if buttnPushCount goes over 133, there may be some excitement.
a7
In my understanding that is "undefined". Please correct me if I'm wrong, I'm not a native English speaker.
I don't know a word for it. I would not use undefined as it sparks in at least my imagination the idea that you are pointing out reference to an array member outside the dimensions of the array, as it " that provokes undefined behaviour".
So in casual conversation I might call it invalid , trash , junk or leftover form last time.
That is to say it is there, but holds a value that is without meaning and might be messing with the analysis of the truly gathered samples.
But maybe it is good you caused me to look at what you were pointing out and wonder what you could possibly mean!
HTH
a7
OK, I wondered if chatGPT might help here, fun! It took a few "course corrections" to get it to understand us, but eventually it typed this, long winded it is.
I see. In that case, you can describe this issue as "Off-by-one Error" or "Off-by-one Bug." This term is commonly used in programming to refer to situations where code incorrectly accesses data located one position before or after the intended location in an array or data structure.
The "Off-by-one Error" typically occurs due to an incorrect loop termination condition or an incorrect index calculation, which leads to accessing the wrong data or a default value (like zero) instead of the intended data.
If the problem is specifically related to picking up a sample from a previous run that gathered more samples, you might also consider using the term "Stale Data" or "Residual Data." This can happen when the code does not properly reset or update certain variables or arrays before starting a new run, leading to unintended data being used in calculations.
I asked it to be a bit less verbose,
Got it! Here's a more concise version:
Issue: Off-by-one Error or Off-by-one Bug
Description: Code goes one step too far in the array, leading to zero values or picking up samples from previous runs.
Optional: Stale Data or Residual Data, if the problem involves using data from previous runs.
HTH and your English is better than my <any language>, maybe even better than my English. :wink:
a7
I'm using the Uno for this exercise. It will be integrated into a script I'm running on a ESP32.
133 is in excess of the absolute maximum number of operations in a 15 minute period, the delay I will eventually use. For this excercise I'm just using a button over a ten second period, so I'll have a hard time pressing the button that many times.
After I made the definition change, the script started to work, so if this wouldn't have caused it, I don't know what did.
Thank you for your comments.
Thanks for pointing that out, I noticed that the results for the last button push were strange, so I'll redo that but tomorrow.
How do you suppress button bounces?
Handling mechanical buttons by interrupts is not a good idea.
