the project:
my goal is to use a arduino UNO to make a artnet node. this will convert artnet to dmx.
hardware: Arduino UNO with a ethernet shield and a proto shield with sn75176 ic connected to digital pin 3 for dmx out.
IDE: arduino 1.0
libraries used: DmxSimple, SPI, Ethernet, EthernetUdp.
Link to DmxSimple Library: Google Code Archive - Long-term storage for Google Code Project Hosting.
The Dmx Simple Library is modified to work with arduino 1.0
The code is 99% made by Christoph Guillermet
original code can be downloaded from here:
http://vvvv.org/contribution/artnet-arduino-set-v2
I have added the dmx out feature to the code and adapted it for Arduino 1.0.
to my problem! This code sort of works. It is working for about 10 seconds of changeing values and then i freezes.
Im guessing this has to do with some sort of memmorie issue. im also guessing it has to do with the DmxSimple library bacuse the original sketch does not have this issues.
Things i have tried: Instead of receiving all of the 512 dmx channels i have tried to limit this to just one. but same thing happens but after ca 25 seconds instead of 10.
so does some one have clue how i can solve this ?
The Code
ARTNET RECEIVER V2
This SCRIPT allows you to use arduino with ethernet shield or wifi shield and recieve artnet data. Up to you to use channels as you want.
If you have implemented ameliorations to this sketch, please, contribute by sending back modifications, ameliorations, derivative sketch. It will be a pleasure
to let them accessible to community
For VVVV patchers, please think to put a mainloop node in your patch: minimum frame rate is 40fps with bulbs. But do not go too much higher ( max 100 fps).
This sketch is part of white cat lighting board suite: /http://www.le-chat-noir-numerique.fr
wich is sending data to many different types of devices, and includes a direct communication in serial also with arduino likes devices
you may find whitecat interresting because its theatre based logic ( cuelist and automations) AND live oriented ( masters, midi, etc)
(c)Christoph Guillermet
karistouf@yahoo.fr
#include <DmxSimple.h>
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
#define short_get_high_byte(x) ((HIGH_BYTE & x) >> 8)
#define short_get_low_byte(x) (LOW_BYTE & x)
#define bytes_to_short(h,l) ( ((h << 8) & 0xff00) | (l & 0x00FF) );
//MAC and IP of the ethernet shield
//MAC adress of the ethershield is stamped down the shield
//to translate it from hexa decimal to decimal, use: http://www.frankdevelopper.com/outils/convertisseur.php
//HARDWARE
byte mac[] = { 144, 162, 218, 00, 16, 96 };//the mac adress of ethernet shield or uno shield board
IPAddress ip(192,168,0,60 );// the IP adress of your device, that should be in same universe of the network you are using, here: 192.168.1.x
// the next two variables are set when a packet is received
byte remoteIp[4]; // holds received packet's originating IP
unsigned int remotePort; // holds received packet's originating port
//customisation: edit this if you want for example read and copy only 4 or 6 channels from channel 12 or 48 or whatever.
const int number_of_channels=512; //512 for 512 channels
const int channel_position=1; // 1 if you want to read from channel 1
// buffers
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to store incoming data
byte buffer_dmx[number_of_channels+channel_position]; //buffer to store filetered DMX data
// art net parameters
unsigned int localPort = 6454; // artnet UDP port is by default 6454
const int art_net_header_size=17;
const int max_packet_size=576;
char ArtNetHead[8]="Art-Net";
char OpHbyteReceive=0;
char OpLbyteReceive=0;
short is_artnet_version_1=0;
short is_artnet_version_2=0;
short seq_artnet=0;
short artnet_physical=0;
short incoming_universe=0;
boolean is_opcode_is_dmx=0;
boolean is_opcode_is_artpoll=0;
boolean match_artnet=1;
short Opcode=0;
EthernetUDP Udp;
//déclaration des ports PWM
//ici une diode pour test
pinMode(3, OUTPUT); //check with leds + resistance in pwm, this will not work with pins 10 and 11, used by RJ45 shield
// démarrage ethernet et serveur UDP
Ethernet.begin(mac,ip);
Udp.begin(localPort);
int packetSize = Udp.parsePacket();
if( packetSize>art_net_header_size && packetSize<=max_packet_size)//check size to avoid unneeded checks
Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
//read header
match_artnet=1;//valeur de stockage
for (int i=0;i<7;i++)
if(char(packetBuffer[i])!=ArtNetHead[i])
{match_artnet=0;break;}//if not corresponding, this is not an artnet packet, so we stop reading
if (match_artnet==1)//if its an artnet header
/*artnet protocole revision, not really needed
is_artnet_version_1=packetBuffer[10];
is_artnet_version_2=packetBuffer[11];*/
/*sequence of data, to avoid lost packets on routeurs
seq_artnet=packetBuffer[12];*/
/*physical port of dmx N°
//artnet_physical=packetBuffer[13];*/
//operator code enables to know wich type of message Art-Net it is
Opcode=bytes_to_short(packetBuffer[9],packetBuffer[8]);
if(Opcode==0x5000)//if opcode is DMX type
is_opcode_is_dmx=1;is_opcode_is_artpoll=0;
else if(Opcode==0x2000)//if opcode is artpoll
is_opcode_is_artpoll=1;is_opcode_is_dmx=0;
//( we should normally reply to it, giving ip adress of the device)
if( is_opcode_is_dmx=1)//if its DMX data we will read it now
//if you need to filter DMX universes, uncomment next line to have the universe rceived
//incoming_universe= bytes_to_short(packetBuffer[15],packetBuffer[14])
//getting data from a channel position, on a precise amount of channels, this to avoid to much operation if you need only 4 channels for example
for(int i=channel_position-1;i< number_of_channels;i++)//channel position
buffer_dmx[i]= byte(packetBuffer[i+17]);
DmxSimple.write(i,buffer_dmx[i]);
}//end of sniffing
![FB_IMG_1458817407373[1].jpg](https://europe1.discourse-cdn.com/arduino/original/3X/a/4/a4427cc140cd80213b14bdff02949b9975e04894.jpg)
