aruindo to read my xbee accelerometer data
am trying to read my accelerometer data though wireless connection . my receiver connected to arduino and i recive this in the serial monitor :
7E 00 0E 83 00 01 3B 00 01 0E 00 01 FB 01 F9 02 70 C9
which is right
7E START packet , 00 0E is my packet length , 83 frame id , 00 01 source id , 3B RSSI , 00 OPTIONS ,01 TOTAL NUMBER OF SAMPLE , 0E 00 HEADER
01 FB 01 F9 02 70 this is my data i need 01 FB = X 01 F9 = Y 02 70 = Z C9 = check sum
am trying to read only my data and discard the other bytes . but how can i assign the vale for X , Y and Z
this is my code i would really appreciate your contribution to help me
am new in coding
thanks :slight_smile:
void readPacket(){  // if serial has 18 bytes which what we need int he buffer my every packets contains 18 bytes
  if (Serial.available() >= 18)  {
   // FIND MY START BIT
    if (Serial.read()==0x7E)
    // read the value we do not need out of the buffer
   for(int i =0 ; i< 11 ; i++);
    byte discard = Serial.read();
 // down here is the problem am trying to read for X Y Z am not sure if this is right ?? i need help
  for(int d=12 ; d<=18 ; d=d+2);
    byte[(12)*256]+(13)]  = Serial.read( ,x);
    byte[(14)*256]+(15)]  = Serial.read( ,y);
    byte [(16)*256]+(17)] =Serial.read(  ,z);
Serial.print(, x );
Serial.print( , Y );
Serial.print( , Z);
Just a quick run down on statements,
int a = 4;
if( a > 3 )
  a++;  //Only this line is part of the above if
  a++; //This will run weather or not the if does anything.
if( a > 4 ){
    a++;  //Both these are part of the same if
    a++;
for( int b = 0 ; b < 5 ; ++b );
  a++; //Due to semicolon on for statement, this a++ is not part of it and will only run once when the loop is finished.
  a++; //This is part of the loop
  a++; //This is not
for( int b = 0 ; b < 5 ; ++b ){
  a++; //These two instructions are part of the loop
  a++;
//This is completely wrong
the '[' and ']' brackets dont match, and byte is a data type, not a variable.
Serial.read( ,x);
Functions cannot have empty paramaters. ( Serial.read doesn't take any paramaters ).
Read this: http://www.cplusplus.com/doc/tutorial/
okay thanks but how can i fix it
in this i mean that my 12th and 13th byte are my x value in my packet fram ,
[(12)*256]+(13)] this is because i have MSB , LSB to be added together for my ADC .
can you help please ?
thanks
That mess has nothing to fix, it is not code.
Here is a re-write of what you were doing, kind of.
void ReadPacket( void )
    if( Serial.available() >= 18 ){
      if (Serial.read()==0x7E ){
          Serial.read();
        int i_Data[ 3 ]; //3 elements for x, y, z
        for(int i =0 ; i< 3 ; i++)
          i_Data[ i ] = makeWord( Serial.read(), Serial.read() );
          i_Data[ 0 ] contains X
          i_Data[ 1 ] contains Y
          i_Data[ 2 ] contains Z
        Serial.print( "X: " );
        Serial.println( i_Data[ 0 ] );
        Serial.print( "Y: " );
        Serial.println( i_Data[ 1 ] );
        Serial.print( "Z: " );
        Serial.println( i_Data[ 2 ] );
    return;
This won't help you unless you know what you were doing wrong. I suggest you read my first post and that link before you confuse yourself further.
yes i agree am totally wrong but really coding is not my thing , am sorry if i wrote stupid code and i wanted you to explain .
however i did another aproch and am getting data from my serial port but they r not correct .
can you check this code please
void setup(){
  delay(100);
  Serial.print("reading.. ");
  readPacket();
void readPacket(){
   //which contains x value for my 12th byte and 13 byte
   if(int i=12 )
    int analogHigh  = Serial.read( );
    int analogLow = Serial.read();
    x = analogLow + (analogHigh * 256);
    Serial.println(x, DEC);
    // he is for my y value for my 14th and 15 byte
    if (int i=14) {
    y = analogLow + (analogHigh * 256);
    Serial.println(y, DEC);
    Serial.flash ();
    // here is for my z value
    if (int i=16){
    z = analogLow + (analogHigh * 256);
    Serial.println(z, DEC);
    Serial.flash ();
ops am really sorry about Serial.flash .
i meant
Serial.Flush
your feedback is important thanks mate for helping me
