Hello,
I want to do something like this:
- define asci escape code of cursor position - for example [20;20H in array (
char* position[] = {"\"[20;20H\"", "\"[25;25H\""};
- then I want to use this coordinates in Serial.write()
Serial.write(27);
Serial.write(position[0]);
- and then print ther something
Serial.print("Something");
What am I doing wrong? A result that I see on Putty terminal emulator is something like that 20:20H"
in random position. Please help me.
What is Serial.write(27) supposed to be doing?
Posting snippets, instead of all of your code.
Not explaining what the code ACTUALLY does.
Not explaining what you are sending the serial data to.
Serial.write(27); is a ESC
Ok my code is:
void setup(){
Serial.begin(9600);}
void loop(){
char* position[]={"\"[22;20H\"" , "\"[25;25H\""};
Serial.write(27); //this means ESC
Serial.write(position[0]); //this should place cursor in right row and column
delay(2000);
A result on Putty is:
[22,20H" Something
Serial.write(postioion[0]) doesn't set a cursor in right place.
Igñoring the spelling, writing a single character isn't going to move the cursor - you need to send the whole string.
position[ 0 ] is a pointer. The function call is correct.
