Ask for newping
I'am new to programming. Please help.
I need to use sensor value form newping to other function. How can I do that.
Thank for every advice. ^^
/////////////////////code////////////
#include <NewPing.h>
#define SONAR_NUM 3
#define MAX_DISTANCE 200
NewPing sonar[SONAR_NUM] = {
 NewPing(2, 3, MAX_DISTANCE),
 NewPing(4, 5, MAX_DISTANCE),
 NewPing(6, 7, MAX_DISTANCE)
 for (uint8_t i = 0; i < SONAR_NUM; i++) {
   delay(50);
   Serial.print(i);
   Serial.print("=");
   Serial.print(sonar[i].ping_cm());
   Serial.print("cm ");
 // I need to use sonar0, sonar1, sonar2 here.
void myFunction() {
 //And I need sonar0, sonar1, sonar2 value here.
Hopefully, you can see why we ask you to use code tags when posting code.
Store the values returned in an array.
AWOL:
Where to see example.
The IDE is jam-packed with examples
The reference has an example of using an array of sensors and storing the returned ranges in an array.
