Dear all,
I recently bought a RFID WL-125 devise for an instalation.
I try to exploit the Identification Number of the card with arduino. The arduino input is in RX. With Serial.read, I can catch some number. See the picture :
with this code :
if (Serial.available()>0)
while(Serial.available())
int data = Serial.read();
Serial.println(data);
The problem is that all the int I have can't be use in this format. I think I have to "assemble" all the number to creat the ID.
Because after, I would like to do : num 02484948705369495254704303 match (or not) with the data base. "approved or disapprove"
Please, is someone can help me ? Thanks a lot in advance !
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
will you please paste your whole program?
The program I sent was the whole one.
I also try this :
#include <SoftwareSerial.h>
unsigned char buffer[64]; // buffer array for data recieve over serial port
int count=0; // counter for buffer array
const int tagLength = 13;
String matchingTag = "010F5E146F+";
Serial.begin(9600); // the Serial port of Arduino baud rate.
Serial.println("RFID module started in Auto Read Mode, Waiting for Card...");
if (Serial.available()) // if date is comming from softwareserial port ==> data is comming from SoftSerial shield
while(Serial.available()) // reading data into char array
buffer[count++]=Serial.read(); // writing data into array
if(count == 64)break;
//Serial.write(buffer,64);
Serial.write(buffer,count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the storaged data from the array
count = 0; // set counter of while loop to zero
void clearBufferArray() // function to clear buffer array
for (int i=0; i<count;i++)
buffer[i]=NULL;
} // clear all index of array with command NULL
but it give me an output value like that : "010F5E1467#" but this is not a String ...
Thank for your help and sorry for my mistake#UKHeliBob ! i am new on this forum.
I think this is HEX. In reality, I can configure the format I want with this fonction :
with : Serial.println(data, HEX);
or with :
Serial.println(data, BIN);
looks like ascii codes to me..
02 Start of Text
48 0
49 1
48 0
70 F
53 5
69 R
49 1
52 4
54 6
70 F
43 +
03 End of text
Thanks a lot for your answer.
Do you have an example of a code whitch can read the serial value from the D0 (RX) of the arduino and put it in a String please?
My programation level is realy bad ... !
you were doing pretty good..
took what you had a worked it a bit for you..
int count = 0; // counter for buffer array
const char matchingTag[] = "010F5E146F+";
clearBuffer();
if (ChecForTag())
if (strcmp(buffer, matchingTag) == 0)
Serial.println("Tag Matched");
Serial.write(buffer, count);
Serial.println("Tag Not Matched");
//clear buff
clearBuffer();
//reset count
count = 0;
void clearBuffer()
for (int i = 0; i < count; i++)
buffer[i] = NULL;
bool ChecForTag()
bool haveTag = false;
//is there a byte
{ //while there is a byte
while (Serial.available())
{ //read a byte
char c = Serial.read();
// SOT, EOT, NL don't include
if (c != 2 && c != 3 && c != 10)
{ //save byte to butter, increase count
if (count < sizeof(buffer)) {
buffer[count] = c;
count++;
} else { //EOT recvd, we have a tag
if (c == 3) haveTag = true; //EOT -end of text
if (c == 10) haveTag = true; //NL - also trigger here in case no EOT, for sim
return haveTag;
try it here..
have fun!! ~q
lol, spelled check wrong.. coding from couch, sorry.. got buffer as butter too but that's a comment so don't count..
Ho my god !!! It is working !!!
See the picture :
Thanks a lot for your contribution
