Async http requests on Arduino Giga r1
I am sending http requests on my Giga r1 to Spotify api and it takes about 3 seconds, in which I can't do anything. I tried different libraries for multithreading but they don't work.
How can I made these requests not block main thread?
3 seconds to get the first byte in response? What kind of response is it? Do you use the body content?
If you perform HTTP manually, you can wait for and then pull the response as part of the main loop
#include <WiFi.h>
#include "arduino_secrets.h"
WiFiClient wifi;
bool hostConnected;
  WiFi.begin(SECRET_SSID, SECRET_PASS);
  for (int i = 0; WiFi.status() != WL_CONNECTED; i++) {
    Serial.print(i % 10 ? "." : "\n.");
    delay(100);
  if (wifi.connect("www.google.com", 80)) {
    hostConnected = true;
    wifi.println("GET / HTTP/1.0");       // 1.0 means not having to request Connection: close, nor set the Host:
    wifi.println("User-Agent: Arduino");  // without a UA, get 55KB of content instead of "normal" 18KB
    wifi.println();
void checkWiFiIncoming() {
  if (!hostConnected) {
    return;
  if (!wifi.connected()) {
    hostConnected = false;
    Serial.println("host disconnected");
    return;
  static unsigned waited;
  int avail = wifi.available();
  if (!avail) {
    ++waited;
    return;
  Serial.print("waited: ");
  Serial.print(waited);
  waited = 0;
  Serial.print("\tto-read: ");
  Serial.print(avail);
  constexpr int max_read = 5120;  // arbitrary chosen, takes effect sometimes
  if (avail > max_read) {
    avail = max_read;
    Serial.print("\ttry-read: ");
  uint8_t buf[avail + 1];
  avail = wifi.read(buf, avail);
  buf[avail] = 0;
  Serial.print("\tdid-read: ");
  Serial.println(avail);
  Serial.println(reinterpret_cast<char *>(buf));
  checkWiFiIncoming();
Skipping the actual content, the data available coming in on my R4 WiFi (don't have a GIGA) looks like this; starting with dozens of loop iterations waiting for a response:
waited: 73	to-read: 1412	did-read: 1023
waited: 0	to-read: 4625	did-read: 1023
waited: 0	to-read: 6546	try-read: 5120	did-read: 1023
waited: 0	to-read: 5523	try-read: 5120	did-read: 1023
waited: 0	to-read: 4500	did-read: 1023
waited: 0	to-read: 3477	did-read: 1023
waited: 0	to-read: 2454	did-read: 1023
waited: 0	to-read: 5763	try-read: 5120	did-read: 1023
waited: 0	to-read: 6176	try-read: 5120	did-read: 1023
waited: 0	to-read: 6589	try-read: 5120	did-read: 1023
waited: 0	to-read: 5566	try-read: 5120	did-read: 1023
waited: 0	to-read: 4543	did-read: 1023
waited: 0	to-read: 4956	did-read: 1023
waited: 0	to-read: 5369	try-read: 5120	did-read: 1023
waited: 0	to-read: 4346	did-read: 1023
waited: 0	to-read: 3323	did-read: 1023
waited: 0	to-read: 2300	did-read: 1023
waited: 0	to-read: 2414	did-read: 1023
waited: 0	to-read: 1391	did-read: 1023
waited: 0	to-read: 368  	did-read: 368
It reads at most 1K at a time. Depending on how big a response you need to see all together at once in a single string, it may require some shuffling. Or maybe you can pass on the response in chunks to whatever needs it next. If it's really small, maybe you can get it in a single read.
Depending on which HTTPClient you're using, you might be able to use that to make the request, and then take over reading the response. Although requests are generally pretty simple. Responses, which might use Transfer-Encoding: chunked for example, can get complicated.
I have this function
int get_spotify_data()
  WiFiClient client;
  client.connect("XXXXX", 80);
  client.println("GET /?operation=get HTTP/1.1");
  client.println("Host: "XXXXX");
  client.println("Connection: close");
  client.println();
  bool headers = true;
  while (client.connected() && headers)
    String line = client.readStringUntil('\n');
    if (line == "\r")
      headers = false;
String responseBody = "";
  while (client.available())
    responseBody += client.readString();
  client.stop();
  char* json = (char*)malloc(responseBody.length() + 1);
  if (json) {
    strcpy(json, responseBody.c_str());
  if (json == "No current song" || json == "Error")
    update_song_info("{'type': 'None','volume': 100,'time': 0,'duration': 0,'name': 'No current song','artist': 'No author'}");
    update_song_info(json);
And these 3 second is from calling this function to " client.stop();"
I just tried your code and I don't have any difference
Before getting to the main issue; the following will not work:
for a few reasons
  • If the API returns JSON, the word by itself, Error, is not JSON. Compare these in your browser's JavaScript console
    > JSON.parse('Error').length
      SyntaxError: JSON Parse error: Unexpected identifier "Error"
    > JSON.parse('"Error"').length
      5
    > JSON.parse("'Error'").length
      SyntaxError: JSON Parse error: Single quotes (') are not allowed in JSON
    A string in JSON must have double quotes. So at a minimum, it would have to be "\"Error\"" and "\"No current song\""
  • Most JSON APIs always return either an object in curly braces { } or an array in square brackets [ ], e.g.
      "error": "this is the error message"
    not a bare string
  • In C, comparing a char * for a newly-allocated block of memory to a hard-coded string will always be not-equal. It's comparing two pointers, even if the text at those pointers is identical. Instead, you can compare a String: responseBody == "\"Error\"", which works as expected; and then to proceed further, make a copy to pass it on. (Be sure to properly free that block when appropriate. Do you even need to make a copy?)
The main issue
I took most of your code, added some instrumentation, and applied it to what I had earlier. Your URL is redacted, so I switched the Google host to get a shorter payload (this may matter). All the changes are in setup
    delay(100);
  if (client.connect("google.com", 80)) {
    client.println("GET / HTTP/1.1");
    client.println("Host: google.com");
    client.println();
  auto start = millis();
  while (client.connected() && headers) {
    if (line == "\r") {
      headers = false;
      Serial.print(millis() - start);
      Serial.print('\t');
      line.trim();
      Serial.println(line);
  // while (hostConnected) {
  //   checkWiFiIncoming();
  // Serial.println(millis() - start);
  while (client.available()) {
    int avail = client.available();
    String part = client.readString();
    Serial.print('\t');
    Serial.print(part.length());
    Serial.print("\t");
    Serial.println(part);
    Serial.print('\t');
    Serial.print('\t');
    Serial.print(responseBody.concat(part) ? "added" : "didn't add");
    Serial.print('\t');
    Serial.println(responseBody.length());
  client.stop();
This prints
122	HTTP/1.1 301 Moved Permanently
126	Location: http://www.google.com/
129	Content-Type: text/html; charset=UTF-8
137	Content-Security-Policy-Report-Only: object-src 'none';base-uri 'self';script-src 'nonce-0jX11fd4RyoH1Xp6ua0X_Q' 'strict-dynamic' 'report-sample' 'unsafe-eval' 'unsafe-inline' https: http:;report-uri https://csp.withgoogle.com/csp/gws/other-hp
159	Date: Tue, 14 Jan 2025 03:20:17 GMT
163	Expires: Thu, 13 Feb 2025 03:20:17 GMT
167	Cache-Control: public, max-age=2592000
171	Server: gws
173	Content-Length: 219
175	X-XSS-Protection: 0
177	X-Frame-Options: SAMEORIGIN
181	Connection: close
	219	<HTML><HEAD><meta http-equiv="content-type" content="text/html;charset=utf-8">
<TITLE>301 Moved</TITLE></HEAD><BODY>
<H1>301 Moved</H1>
The document has moved
<A HREF="http://www.google.com/">here</A>.
</BODY></HTML>
1209	219	added	219
host disconnected
It took 122ms to get the initial response line with the 301 status code. Another 60ms to get the rest of the headers, and then just over a second to read 219 bytes in the body in a single part. This is due to how readString works: unlike readStringUntil, the only way it can stop is due to a timeout with no-more-characters, which defaults to one second.
Now note the four commented-out lines in the middle. Uncomment them:
to use the existing function in my sketch that does not use readString, so now a run looks like this
181	HTTP/1.1 301 Moved Permanently
185	Location: http://www.google.com/
189	Content-Type: text/html; charset=UTF-8
196	Content-Security-Policy-Report-Only: object-src 'none';base-uri 'self';script-src 'nonce-he0o3-zgUrxPyVA1z77EnQ' 'strict-dynamic' 'report-sample' 'unsafe-eval' 'unsafe-inline' https: http:;report-uri https://csp.withgoogle.com/csp/gws/other-hp
218	Date: Tue, 14 Jan 2025 03:38:08 GMT
222	Expires: Thu, 13 Feb 2025 03:38:08 GMT
226	Cache-Control: public, max-age=2592000
230	Server: gws
232	Content-Length: 219
234	X-XSS-Protection: 0
237	X-Frame-Options: SAMEORIGIN
240	Connection: close
waited: 0	to-read: 219	did-read: 219
<H1>301 Moved</H1>
</BODY></HTML>
host disconnected
277
Just over a quarter-second total:
  • The response starts 60ms later than before, which is expected to vary
  • Still takes 60ms to read the headers, one at a time, and print them
  • But now it only takes 37ms to read the remaining body, in one part/call
You're going to have to clarify. Using readString takes an extra second. By avoiding it, instead of 3 seconds, it could be two. But that could still be considered blocking for too long. Running the instrumented code, you can see where the delays are.
As I show, you can call out to a response-reader from the main loop function, so that whatever else you're doing can still run in the meantime.
  • Waiting for the first byte back would take "no time"
  • Each header line read separately, so you can act upon them, would take around 10ms each
  • By limiting the amount that is read, each part of the body could be maybe 50ms or less.
What does a valid JSON response look like? How big is it?
