AT24C32 EEPROM HELP
Its a bit complicated for me.
I trying to make an altimeter+ data-logger for small model rockets.
I am using DS1307 RTC, AT24C32 EEPROM and BME 280 Altimeter.
All i need is
first save a date stamp into EEPROM using RTC data, for this i need to manipulate data into some format. I need some help here.
second I need to take a reading of height achieved in every 5 second and save to EEPROM.
like
00:00
05:20
10:40
15:60
etc
about AT24C32, i am a bit confused while using mem.write(12, 42); what is the starting and ending address in this EEPROM i am not sure.
any help is appreciated, I am totally noob when it comes to coding.
thanks.
The device has 4096 locations, so the lowest address is zero, and the highest address is 4095
A small part of my program. You can search for the library <EEPROMex.h>
EEPROM.writeFloat(100, offset_1);
EEPROM.writeFloat(104, offset_2);
EEPROM.writeFloat(108, offset_3);
EEPROM.writeFloat(112, offset_4);
Don't confuse commands used for the internal EEPROM in the Arduino. An AT24C32 is an external device and uses I2C to communicate with. You might want to look at the extEEPROM library by Jack Christensen.
Code: [Select]
mem.write(12, 42);
The conceptual view for the memory location, location address, and location content of a AT24C32 EEPROM are depicted in the above figure.
The command (taken from AT24CX.h Library) to write a data byte (say, 42 = 0x2A) into an EEPROM location (aka location address = locAdr) (say, 12 = 000C):
mem.write(locAdr, dataByte)
==> mem.write(12, 42);     //one byte enters into one memory location;
==> mem.write(0x000C, 0x2A);
The following example file taken from the same header file contains all possible commands:
* Read and write demo of the AT24CX library
* Written by Christian Paul, 2014-11-24
// include libraries
#include <Wire.h>
#include <AT24CX.h>
// EEPROM object
AT24CX mem;
// setup
  // serial init
  Serial.println("AT24CX read/write demo");
  Serial.println("----------------------");
// main loop
  // read and write byte
  Serial.println("Write 42 to address 12");
  mem.write(12, 42);
  Serial.println("Read byte from address 12 ...");
  byte b = mem.read(12);
  Serial.print("... read: ");
  Serial.println(b, DEC);
  // read and write integer
  Serial.println("Write 65000 to address 15");
  mem.writeInt(15, 65000);
  Serial.println("Read integer from address 15 ...");
  unsigned int i = mem.readInt(15);
  Serial.println(i, DEC);
  // read and write long
  Serial.println("Write 3293732729 to address 20");
  mem.writeLong(20, 3293732729UL);
  Serial.println("Read long from address 20 ...");
  unsigned long l = mem.readLong(20);
  Serial.println(l, DEC);
  Serial.println("Write 1111111111 to address 31");
  mem.writeLong(31, 1111111111);
  Serial.println("Read long from address 31 ...");
  unsigned long l2 = mem.readLong(31);
  Serial.println(l2, DEC);
  // read and write float
  Serial.println("Write 3.14 to address 40");
  mem.writeFloat(40, 3.14);
  Serial.println("Read float from address 40 ...");
  float f = mem.readFloat(40);
  Serial.println(f, DEC);
  // read and write double
  Serial.println("Write 3.14159265359 to address 50");
  mem.writeDouble(50, 3.14159265359);
  Serial.println("Read double from address 50 ...");
  double d = mem.readDouble(50);
  Serial.println(d, DEC);
  // read and write char
  Serial.print("Write chars: '");
  char msg[] = "This is a message";
  Serial.print(msg);
  Serial.println("' to address 200");
  mem.writeChars(200, msg, sizeof(msg));
  Serial.println("Read chars from address 200 ...");
  char msg2[30];
  mem.readChars(200, msg2, sizeof(msg2));
  Serial.print("... read: '");
  Serial.print(msg2);
  Serial.println("'");
  // write array of bytes
  Serial.println("Write array of 80 bytes at address 1000");
  byte xy[] = {0,0,0,1,1,1,2,2,2,3,3,3,4,4,4,5,5,5,6,6,6,7,7,7,8,8,8,9,9,9,    // 10 x 3 = 30
              10,11,12,13,14,15,16,17,18,19,                                   //          10
              120,121,122,123,124,125,126,127,128,129,                         //          10
              130,131,132,133,134,135,136,137,138,139,                         //          10
              200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217,218,219};                   //          20
  mem.write(1000, (byte*)xy, sizeof(xy));
  // read bytes with multiple steps
  Serial.println("Read 80 single bytes starting at address 1000");
  for (int i=0; i<sizeof(xy); i++) {
    byte sb = mem.read(1000+i);
    Serial.print("[");
    Serial.print(1000+i);
    Serial.print("] = ");
    Serial.println(sb);
  // read bytes with one step
  Serial.println("Read 80 bytes with one operation at address 1000");
  byte z[80];
  memset(&z[0], 32, sizeof(z));
  mem.read(1000, z, sizeof(z));
  for (int i=0; i<sizeof(z); i++) {
    Serial.print("[");
    Serial.println(z[i]);
  // stop
  while (1==1) {}
Data Logger Tutorial using: UNO + BMP180 + DS1307 + 24C32 + SM
A: System in Block Diagram
B: Operating Procedures
(1) Altitude is computed in every 5-sec interval.
(2) The altitude is shown on Serial Monitor at every 5-sec interval with Day, Date, and Time Stamp.
(3) The altitude is recorded in EEPROM at every 5-sec interval with Day, Date, and Time Stamp.
(4) When K1 button (Stop Logging) is held down for more than 5-sec, the logging is stopped. The very 1st sample of the logged data is read back from EEPROM and is shown on the Serial Monitor.
C: Complete Program Codes (Extensive help and references are taken from IDE Examples)
#include <SFE_BMP180.h>
#include <Wire.h>
#include "RTClib.h"
#include <AT24CX.h>
SFE_BMP180 pressure;
AT24CX mem;
RTC_DS1307 rtc;
char msg[100];
unsigned int x;
char daysOfTheWeek[7][12] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
unsigned int locAdr = 0x0200;
#define ALTITUDE 4.0//Dhaka 1655.0 // Altitude of SparkFun's HQ in Boulder, CO. in meters
String string = "";
  pinMode(8, INPUT_PULLUP);
  if (pressure.begin())  //calibration values are read from onboard eeprom of sensor
     Serial.println("BMP180 init success");
    Serial.println("BMP180 init fail\n\n");
    while(1); // Pause forever.
  if (! rtc.begin())
    Serial.println("Couldn't find RTC");
    while (1);
  if (! rtc.isrunning())
    Serial.println("RTC is NOT running!");
   rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));//auto update from computer time
   //rtc.adjust(DateTime(2014, 1, 21, 3, 10, 17));// to set the time manualy
void  loop()
  dayDateTime();
  computedAltitude();
  if(digitalRead(8) == LOW)
    Serial.println("OK! Logging is Terminated!! Reading Back EEPROM's Data!!!");
    locAdr = 0x0200;
    mem.readChars(locAdr, msg, x);
    Serial.println(msg);
    HERE: goto HERE;
  logToEeprom();
  delay(5000);
void computedAltitude()
  char status;
  double T,P,p0,a;
  status = pressure.startTemperature();
  if (status != 0)
    // Wait for the measurement to complete:
    delay(status);
    status = pressure.getTemperature(T);
    if (status != 0)
      status = pressure.startPressure(3);
      if (status != 0)
        delay(status);
        status = pressure.getPressure(P,T);
        if (status != 0)
           p0 = pressure.sealevel(P,ALTITUDE); // we're at 1655 meters (Boulder, CO)
          a = pressure.altitude(P,p0);
          string += "      ";
          string += "Computed Altitude: ";
          string += a;
          string += " meters";
      Serial.println(string);
      x = string.length();
      string.getBytes(msg, x+1);
      string = "";
          Serial.println("error retrieving pressure measurement\n");
        Serial.println("error starting pressure measurement\n");
      Serial.println("error retrieving temperature measurement\n");
    Serial.println("error starting temperature measurement\n");
void dayDateTime()
    DateTime nowTime = rtc.now();//now() reads current Date and Time from RTC
    string += daysOfTheWeek[nowTime.dayOfTheWeek()];
    string += " : ";
    string += nowTime.day();
    string += "/";
    string += nowTime.month();
    string += "/";
    string += nowTime.year();
    string += "     ";
    string += nowTime.hour();
    string += " : ";
    string += nowTime.minute();
    string += " : ";
    string += nowTime.second();
void logToEeprom()
  mem.writeChars(locAdr, msg, x+1);  //extra 1 is to count the null character (x is without null character)
  locAdr = locAdr+x;
That's an interesting attitude to memory conservation.
But then, you're also using String, so, meh.
This is not mine; it belongs to IDE's Example.
Yes! There have been a lot of complains from the Forum about the use of String object (one auto complain will come soon from @Robin2); but, the Arduino Reference Manual supports its use!!
So why bother reposting it here, if you know it is sub-optimal?
My car speedometer goes to waaaay over the national speed limit, but it doesn't mean to say I have to use all of it.
I have used the resource (char daysOfTheWeek[7][12]) for my purposes without noticing its special feature of memory conservation. I have to declare my position as to whom this property belongs so that I don't confuse others to offer me something which I don't deserve.
In this practical world, we have to (indeed we do) live with safety hazards; but, we are safe (does not mean protected) as long as we are aware about these hazards which could explode!
I read that as " I can't count past four".
I've seen a very small old petrol engine push a rod through the block, but can't imagine a modwrn two litre turbo diesel blowing up. I should try harder.
I don't understand that sentence.
Will you please, explain with example in what way the above declaration saves memory space. And also, why does the declaration contain [7][12] instead of [7][4]?
GolamMostafa:
Will you please, explain with example in what the above declaration saves memory space. And also, why does the declaration contain [7][12] instead of [7][4]?
Sarcasm hasn't yet made it to your corner of the world, I take it.
Let me borrow it for a few minutes... 8)
