Hello,
I use this sensor in my project ...
Everything works but I wanted to know what this command (Adafruit_AHTX0 aht;) means and I did not find an answer in Google, can anyone please help?
Adafruit_AHTX0 aht;
Creates an object that is an instance of the Adafruit_AHTX0 library and it is named named aht so that subsequent commands can be sent to it and data read from it using its name
If you had 2 such devices you could do
Adafruit_AHTX0 aht0;
Adafruit_AHTX0 aht1;
to create 2 instances and refer to them separately by their names
Thank you very much!
Can you please also tell me what this command is?
sensors_event_t humidity, temp;
That line declares two variables of type sensors_event_t.
Study the Adafruit help pages and library documentation carefully.
Thanks, yes I think I should go through the library...
