ATM System With Arduino Refuses To Work, Help will be much appreciated ๐Ÿ˜Š
I am working on a code for an ATM Machine with an MFRC52 Reader, The code has to read points from a particular block on the rfid card which is like the debit card then Display it on an LCD display with an I2C module and when a button is pressed add one point to the cards internal storage and then display the new value on an LCD display after that, update the new value to the same block on the card which is like adding money to a debit card and then display that you can remove your card now
This is Where I have gotten so far
#include <Wire.h>  // Include Wire library for I2C communication
#include <LiquidCrystal_I2C.h> // Include LiquidCrystal_I2C library for LCD display
#include <SPI.h>  // Include SPI library for MFRC52 reader
#include <MFRC522.h> // Include MFRC52 library for RFID reader
#define SS_PIN 10  // Define SS_PIN for MFRC52 reader
#define RST_PIN 9  // Define RST_PIN for MFRC52 reader
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC52 object
LiquidCrystal_I2C lcd(0x27, 16, 2); // Create LCD object with I2C address and size
const int buttonPin = 2; // Define button pin
int buttonState = 0; // Initialize button state
  Serial.begin(9600); // Initialize serial communication
  SPI.begin(); // Initialize SPI communication
  mfrc522.PCD_Init(); // Initialize MFRC52 reader
  lcd.init(); // Initialize LCD display
  lcd.backlight(); // Turn on backlight
  // Check if a card is present
  if (mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial()) {
    Serial.println("Card detected!");
    // Read data from the card
    byte blockNumber = 4; // Define block number to read
    byte buffer[18];
    byte size = sizeof(buffer);
    MFRC522::StatusCode status = mfrc522.MIFARE_Read(blockNumber, buffer, &size);
    if (status == MFRC522::STATUS_OK) {
      Serial.print("Points: ");
      Serial.println(buffer[0]);
      // Display data on the LCD
      lcd.clear();
      lcd.setCursor(0, 0);
      lcd.print("Points: ");
      lcd.print(buffer[0]);
      // Wait for button press
      while (digitalRead(buttonPin) == LOW) {
        delay(10);
      // Increment points and update the card
      buffer[0]++; // Increment points
      status = mfrc522.MIFARE_Write(blockNumber, buffer, 16);
        // Display updated data on the LCD
        lcd.setCursor(0, 1);
        lcd.print("New points: ");
        lcd.clear();
        lcd.print("Remove card.");
      Serial.println("Error reading data from card.");
    mfrc522.PICC_HaltA(); // Halt card
    mfrc522.PCD_StopCrypto1(); // Stop encryption on PCD
But Something is wrong and I really need your help
THis is the Serial Monitor
And This is What is Happening
ezgif-3-c0e2a19f33
OKay so Update - I am trying this code that looks more promising, I really need help as i am brand new tot his stuff
#include <Wire.h>
#define SS_PIN 10
#define RST_PIN 9
LiquidCrystal_I2C lcd(0x3F, 16, 2);
int buttonPin = 2;
int points = 0;
  SPI.begin();
  mfrc522.PCD_Init();
  lcd.init();
  lcd.backlight();
  pinMode(buttonPin, INPUT_PULLUP);
  // Look for new cards
    byte trailerBlock = 7;
    byte buffer[18];
    // Authenticate using key A
    if (mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &mfrc522.uid, &(mfrc522.keyA))) {
      // Read data from the block
      if (mfrc522.MIFARE_Read(blockNumber, buffer, &size) == MFRC522::STATUS_OK) {
        // Extract the points
        points = buffer[0];
        Serial.println(points);
        lcd.clear();
        lcd.print(points);
        lcd.print("Hold card & press");
        while (digitalRead(buttonPin) == HIGH) {}
        // Add ten points
        points += 10;
        Serial.print("New points: ");
        lcd.clear();
        lcd.print("Credit Added");
        lcd.print("Remove card");
        // Write the new points to the block
        buffer[0] = points;
        if (mfrc522.MIFARE_Write(blockNumber, buffer, 16) == MFRC522::STATUS_OK) {
          Serial.println("Points updated on card");
      // Stop crypto1 communication
    // Halt PICC
    lcd.clear();
But Now Im gettin this
Compilation error: 'class MFRC522' has no member named 'keyA'
keyA is on line 32
Where did you get this code?
What is this KeyA?
Try this code:
Added line 14 and modified line 34.
#include <Wire.h>
#define SS_PIN 10
#define RST_PIN 9
int buttonPin = 2;
int points = 0;
MFRC522::MIFARE_Key keyA;
  SPI.begin();
  mfrc522.PCD_Init();
  lcd.init();
  lcd.backlight();
    byte buffer[18];
    if ((MFRC522::StatusCode) mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &keyA, &(mfrc522.uid))) {
        points = buffer[0];
        lcd.clear();
        lcd.print(points);
        // Add ten points
        points += 10;
        lcd.clear();
        buffer[0] = points;
    // Halt PICC
    lcd.clear();
Thanks a ton for your help, i will get back to you
Okay, Update, I am getting no response anywhere, even in the serial monitor, nothing seems to be happening
run this code and check if the LCD reads:
"Start:"
#include <Wire.h>
#define SS_PIN 10
#define RST_PIN 9
int buttonPin = 2;
int points = 0;
  SPI.begin();
  mfrc522.PCD_Init();
  lcd.init();
  lcd.backlight();
  lcd.print("Start: ");
    byte buffer[18];
        points = buffer[0];
        lcd.clear();
        lcd.print(points);
        // Add ten points
        points += 10;
        lcd.clear();
        buffer[0] = points;
    // Halt PICC
    lcd.clear();
Nope, Nothing
Hi, for when your prof. requested this project?
See if this tw code helps you earn points with your prof.
#include <Wire.h>
#define SS_PIN 10
#define RST_PIN 9
int buttonPin = 2;
int points = 0;
MFRC522::MIFARE_Key key;
  Serial.begin(9600); // Initialize serial communications with the PC
  SPI.begin();        // Init SPI bus
  lcd.init();
  //lcd.begin(16, 2);
  lcd.backlight();
  mfrc522.PCD_Init(); // Init MFRC522 card
  // Prepare the key (used both as key A and as key B)
  // using FFFFFFFFFFFFh which is the default at chip delivery from the factory
  for (byte i = 0; i < 6; i++) {
    key.keyByte[i] = 0xFF;
  Serial.println(F("Scan a MIFARE Classic PICC to demonstrate read and write."));
  Serial.print(F("Using key (for A and B):"));
  dump_byte_array(key.keyByte, MFRC522::MF_KEY_SIZE);
  Serial.println(F("BEWARE: Data will be written to the PICC, in sector #1"));
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  // Show some details of the PICC (that is: the tag/card)
  Serial.print(F("Card UID:"));
  dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
  Serial.print(F("PICC type: "));
  MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
  Serial.println(mfrc522.PICC_GetTypeName(piccType));
  // Check for compatibility
  if (    piccType != MFRC522::PICC_TYPE_MIFARE_MINI
          &&  piccType != MFRC522::PICC_TYPE_MIFARE_1K
          &&  piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
    Serial.println(F("This sample only works with MIFARE Classic cards."));
    return;
  // In this sample we use the second sector,
  // that is: sector #1, covering block #4 up to and including block #7
  byte sector         = 1;
  byte blockAddr      = 4;
  byte dataBlock[]    = {
    0x00, 0x00, 0x00, 0x00, //  0, 0, 0, 0,
    0x00, 0x00, 0x00, 0x00  //  0, 0, 0, 0
  MFRC522::StatusCode status;
  byte buffer[18];
  Serial.println(F("Authenticating using key A..."));
  status = (MFRC522::StatusCode) mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(mfrc522.uid));
  if (status != MFRC522::STATUS_OK) {
    Serial.print(F("PCD_Authenticate() failed: "));
    Serial.println(mfrc522.GetStatusCodeName(status));
    return;
  status = (MFRC522::StatusCode) mfrc522.MIFARE_Read(blockAddr, buffer, &size);
    Serial.print(F("MIFARE_Read() failed: "));
  Serial.print(F("Data in block ")); Serial.print(blockAddr); Serial.println(F(":"));
  dump_byte_array(buffer, 16); Serial.println();
  // Authenticate using key B
  Serial.println(F("Authenticating again using key B..."));
  status = (MFRC522::StatusCode) mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_B, trailerBlock, &key, &(mfrc522.uid));
    return;
  points = buffer[0];
  lcd.clear();
  lcd.print(points);
  // Add ten points
  points += 10;
  lcd.clear();
  dataBlock[0] = points;
  status = (MFRC522::StatusCode) mfrc522.MIFARE_Write(blockAddr, dataBlock, 16);
    Serial.print(F("MIFARE_Write() failed: "));
  // Read data from the block (again, should now be what we have written)
  Serial.print(F("Reading data from block ")); Serial.print(blockAddr);
  Serial.println(F(" ..."));
  // Halt PICC
  lcd.clear();
void dump_byte_array(byte *buffer, byte bufferSize) {
  for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i], HEX);
