UART Issues with atmega 2560
Hello everyone,
So I have an issue with the UART configuration of my customized uC based on the ATmega2560.
To establish serial communication, I'm using the FT232RL chip and the Arduino IDE.
I've basically used the schematic of the arduino nano as a reference except that my usb connector is type A.
I don't have any issues with the converter because through the FT_PROG program, I can detect the device. Also, a loopback test has been successful.
Regarding the baud rate, for the FT232RL, it has been configured through the COM port (Device Manager on Windows) at 9600. In the implemented code, the baud rate of serial.begin() is also set to 9600.
My problem arises from the fact that the ATmega outputs strange characters on the serial monitor. I've looked at the waveform on the oscilloscope of pin 46 (TX) and it's heavily distorted. I first tested on UART1 and then UART0, and the result is the same.
Additionally, I've configured the Fuse Bits through the Microchip software as EFUSE : 0xFD, HFUSE : 0xD8, LFUSE : 0xFF & LOCK BITS : 0xCF .
Inside the ATmega, I'm using the original Arduino ATmega2560 bootloader.
Do people experienced with the ATmega2560 have any idea what the problem might be? Is it a Fuse Bits issue or something else?
Thanks!
