I've been trying to figure how why my board keeps restarting after this program. What it does is to set up Serial and Serial1, then set up all analog pins with PCINT, count pulses on these pins. But the program keeps restarting. I had print statements before and after setting up the PCINT. Once PCINT is set up, any use of Serial1 will cause restart so the message in setup is repeated endlessly.
In a separate program I checked the correctness of the mask and PCICR values and I enabled the correct mask and PCINT group. Serial1 pins are on group 3 and I enabled group 0. Any idea what could have caused this?
const unsigned long hi_baud=2000000; // Serial
const unsigned long lo_baud=9600; // Serial1
const int total_digital=8; // Total digital inputs. Max=8
byte oldPINA=0; // Sensor port
volatile unsigned long cts[total_digital]; // Buffer for PCINT0 to count pulses between couting periods. This changes each time a new pulse is detected and is cleared once its values are read into cnts_meas.
volatile unsigned long cts_meas[total_digital]; // Buffer for PCINT3 to store pulse counts after each counting period expires. This changes once each period, not each time a new pulse is detected.
void pciSetup(byte pin)
*digitalPinToPCMSK(pin) |= bit (digitalPinToPCMSKbit(pin)); // enable pin
PCIFR |= bit (digitalPinToPCICRbit(pin)); // clear any outstanding interrupt
PCICR |= bit (digitalPinToPCICRbit(pin)); // enable interrupt for the group
ISR (PCINT0_vect) // handle pin change interrupt for A7 to A0
static byte newPINA,changePINA;
newPINA=PINA;
changePINA=newPINA^oldPINA;
for (byte i=0;i<8;i++)
cts[7-i]+=changePINA&1; // PIN number and Arduino A0-7 number are reverse of each other.
changePINA=changePINA>>1;
oldPINA=newPINA;
void setup_pulse_pcint() // Sets up PCINT on all input pins for pulse input. Also clears pulse count arrays.
for (byte i=A0;i<=A7;i++) // Enable PCINT on these pins
pinMode(i,INPUT_PULLUP);
pciSetup(i);
cts[1]=0;
cts_meas[i]=0;
oldPINA=PINA;
Serial.begin(hi_baud);
Serial1.begin(lo_baud);
Serial.println("Hello1");
Serial1.println("Hello1");
setup_pulse_pcint();
Serial.println("Hello2");
Serial1.println("Hello2");
