I'm new to Arduino and I'm working on a project.
I need to control a 5-wire stepper motor with my Arduino board.
I want to use L293D as my driver.
I use my computer's usb to power the Arduino board.
My question is, can I power up the L293D using the Arduino board or do I need to use a separate power supply?
How can I use the L293D to drive the motor?
I want to know the exact circuit configuration to do this.
Well the answer to an either-or can't be "yes"... Power the motors (And L293D's Vs) separately from the Arduino. The Vss pin on the L293D is logic supply and should be the Arduino's 5V. Just be sure to use a common ground and have decoupling for the L293D's Vs
What if I use an external power supply to power the arduino, does it mean that I can now use the 5V of the arduino as a supply to the L293D and the motor?
The Arduino's 5V supply can barely handle the L293D's logic section. Barely meaning after a few hours of run, the regulator will be on the virge of thermal shutdown and the Arduino will be wiggy at best.
