I had an Arduino mega, atmega16u2 with a faulty chip, therefore, i swapped the IC for a new one, the problem is after the fix i can only not program the chip i tried the following :
1_using flip bootloader that was provided on the website
2_ I changed bootloader :
3_diffrent baud rate speed
4_change crystal
5_diffrent DFU files
none of the above solutions did work for me, then i proceeded to try another way that i found out with any baud rate speed i receive 1/8 of the initial speed but no luck there too all DFU file had the same problem, i tried the same procedure with normal Arduino and i had no problems
