I am putting ATMEGA328P on my board ( PCB, custom built). I was wondering that is there any programmer that I can use to program the ATMEGA328P without putting any USB chip on my board but can use JTAG connector.
I saw the following programming setup on the Digikey. Can I use this programmer to program the ATMEGA328P using JTAG? I think that this programmer to work, I need to put the JTAG connector on my board but I can not find TDI, TDO, TCLK and TMS on ATMEGA328P.
Atmega328P does not support JTAG. You need to move up to a 1284P, 2561, or 2560 for that.
Put a 6-pin ICSP header, or make the pins (Reset-Gnd-SCK-MISO-MOSI-Power) available to a programming adapter cable, and use another Arduino to install a bootloader:
then you can download serially with a USB/Serial adapter such FTDI Basic, and use the serial port for debugging via Serial.print(). Add an FTDI header, or make the pins (Rx, Tx, DTR, GND, Power) available to connect an adapter cable.
