I'm fairly new to Arduino and I've created an app for the Nano series with RS-232/LED connections. I'm using a small test program to learn the in's and out's of creating the library. I was able to create a library using the .h/.cpp listed below but when I try to make it a precompiled library, I'm failing to resolve in the link phase. I've read, probably 20+ posts that describe how to build by changing the library.properties with the dot_a_linkage and then changing to the precompile=true plus the -l flag.
I've managed to create a .a file (and grab it). Rename it and put it, where I think it belongs. I'm using IDE 1.8.15 (tried it on beta 2.0 with same results). The issue is when I attempt to compile it with just the .h / .a and .ino code, I get the dreaded "undefined reference".
I'm going to post the code here: <myL.h>
#ifndef MY_L_H
#define MY_L_H
#include <Arduino.h>
void setupSerial();
void GotParamOne(String myUser, String myPassword);
void GotParamTwo();
#endif
<myL.cpp>
#include "myL.h"
inline String user;
inline String password;
void setupSerial() {
Serial.println("setup Serial");
void GotParamOne(String myUser, String myPassword) {
Serial.println("Got this passed: ");
Serial.println(myUser);
Serial.println(myPassword);
void GotParamTwo() {
Serial.println("Got this just known: ");
Serial.println(user);
Serial.println(password);
<TestingLibraryFunctions.ino>
#include <myL.h>
String user = "admin";
String password = "123a456";
setupSerial();
GotParamOne(user, password);
GotParamTwo();
Serial.println("Done");
The error messags is very large but I'll post it here.:
Arduino: 1.8.15 (Windows 8.1), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\TESTJohnson\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\TESTJohnson\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\TESTJohnson\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10815 -build-path C:\Users\TESTMI~1\AppData\Local\Temp\arduino_build_848079 -warnings=default -build-cache C:\Users\TESTMI~1\AppData\Local\Temp\arduino_cache_155509 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\TESTJohnson\Documents\Arduino\TestingLibraryFunctions\TestingLibraryFunctions.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\TESTJohnson\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\TESTJohnson\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\TESTJohnson\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10815 -build-path C:\Users\TESTMI~1\AppData\Local\Temp\arduino_build_848079 -warnings=default -build-cache C:\Users\TESTMI~1\AppData\Local\Temp\arduino_cache_155509 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\TESTJohnson\Documents\Arduino\TestingLibraryFunctions\TestingLibraryFunctions.ino
Using board 'nano' from platform in folder: C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\TESTJohnson\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\sketch\\TestingLibraryFunctions.ino.cpp" -o nul
Alternatives for myL.h: [myL]
ResolveLibrary(myL.h)
-> candidates: [myL]
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "-IC:\\Users\\TESTJohnson\\Documents\\Arduino\\libraries\\myL" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\sketch\\TestingLibraryFunctions.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "-IC:\\Users\\TESTJohnson\\Documents\\Arduino\\libraries\\myL" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\sketch\\TestingLibraryFunctions.ino.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "-IC:\\Users\\TESTJohnson\\Documents\\Arduino\\libraries\\myL" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\sketch\\TestingLibraryFunctions.ino.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\sketch\\TestingLibraryFunctions.ino.cpp.o"
Compiling libraries...
Compiling library "myL"
Compiling core...
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring_pulse.S.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\WInterrupts.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring_analog.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring.c" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\hooks.c" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\hooks.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring_digital.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring_shift.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring_pulse.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\HardwareSerial.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\CDC.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\IPAddress.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\PluggableUSB.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\Print.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\Print.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\Stream.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\Tone.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\USBCore.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\WMath.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\WString.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\WString.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\abi.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\abi.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\main.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\main.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\new.cpp" -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\new.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring_pulse.S.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\WInterrupts.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\hooks.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring_analog.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring_digital.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring_pulse.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\wiring_shift.c.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\CDC.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\HardwareSerial.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\IPAddress.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\PluggableUSB.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\Print.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\Stream.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\Tone.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\USBCore.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\WMath.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\WString.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\abi.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\main.cpp.o"
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\core.a" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\core\\new.cpp.o"
Archiving built core (caching) in: C:\Users\TESTMI~1\AppData\Local\Temp\arduino_cache_155509\core\core_arduino_avr_nano_cpu_atmega328_ce257e1bd01adf15d50eef165f9c0fc8.a
Linking everything together...
"C:\\Users\\TESTJohnson\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079/TestingLibraryFunctions.ino.elf" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079\\sketch\\TestingLibraryFunctions.ino.cpp.o" "C:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079/core\\core.a" "-LC:\\Users\\TESTMI~1\\AppData\\Local\\Temp\\arduino_build_848079" -lm
C:\Users\TESTMI~1\AppData\Local\Temp\cc07paeq.ltrans0.ltrans.o: In function `setup':
C:\Users\TESTJohnson\Documents\Arduino\TestingLibraryFunctions/TestingLibraryFunctions.ino:8: undefined reference to `setupSerial()'
C:\Users\TESTJohnson\Documents\Arduino\TestingLibraryFunctions/TestingLibraryFunctions.ino:10: undefined reference to `GotParamOne(String, String)'
C:\Users\TESTJohnson\Documents\Arduino\TestingLibraryFunctions/TestingLibraryFunctions.ino:12: undefined reference to `GotParamTwo()'
collect2.exe: error: ld returned 1 exit status
Using library myL in folder: C:\Users\TESTJohnson\Documents\Arduino\libraries\myL (legacy)
exit status 1
Error compiling for board Arduino Nano.
If you got this far and have any suggestions, I'd really appreciate it. I'm pretty well stumped at this point.
Cheers,
Gary M
