attiny85 with mcp4921 dac challange
Dear readers,
I need help. I have a project. In this project i have the wish to read analog voltage with the attiny85, do a correction on the reading and then send an analog voltage out, with help of a dac mcp4921.
As i am pretty new to Arduino, i depend on the internet. I got a Nano and the mcp47xx working. That combi uses I2C. The Attiny85 and MCP4921 talk SPI. And thats where i got stuck.
I would really appreciate your help......Please do.
Here is the script i have sofar.
// RESET  Ain0 (D 5) PB5  1|    |8  Vcc
// CLK1   Ain3 (D 3) PB3  2|    |7  PB2 (D 2) Ain1  SCK  / USCK / SCL
// CLK0   Ain2 (D 4) PB4  3|    |6  PB1 (D 1) pwm1  MISO / DO
//                   GND  4|    |5  PB0 (D 0) pwm0  MOSI / DI / SDA
namespace tinySPI
 const byte DI   = 0;  // D0, pin 5  Data In
 const byte DO   = 1;  // D1, pin 6  Data Out (this is *not* MOSI)
 const byte USCK = 2;  // D2, pin 7  Universal Serial Interface clock
 const byte SS   = 3;  // D3, pin 2  Slave Select
 void begin ()
   digitalWrite (SS, HIGH);  // ensure SS stays high until needed
   pinMode (USCK, OUTPUT);
   pinMode (DO,   OUTPUT);
   pinMode (SS,   OUTPUT);
   pinMode (DI,   INPUT);
   USICR = bit (USIWM0);  // 3-wire mode
   }  // end of tinySPI_begin
 // What is happening here is that the loop executes 16 times.
 // This is because the 4-bit counter in USISR is initially zero, and then
 // toggles 16 times until it overflows, thus counting out 8 bits (16 toggles).
 // The data is valid on the clock leading edge (equivalent to CPHA == 0).
 byte transfer (const byte b)
   USIDR = b;  // byte to output
   USISR = bit (USIOIF);  // clear Counter Overflow Interrupt Flag, set count to zero
   do
     USICR = bit (USIWM0)   // 3-wire mode
           | bit (USICS1) | bit (USICLK)  // Software clock strobe
           | bit (USITC);   // Toggle Clock Port Pin
     } while ((USISR & bit (USIOIF)) == 0);  // until Counter Overflow Interrupt Flag set
   return USIDR;  // return read data
   }    // end of tinySPI_transfer
 };  // end of namespace tinySPI
 // en dan nu doen we iets ermee
 void setup (void)
 tinySPI::begin ();
 }  // end of setup
void loop (void)
 int value = 0;
 for (int i=0; i<4; i++) value = value + analogRead(A2);
 // enable Slave Select
 digitalWrite(tinySPI::SS, LOW);
   tinySPI::transfer (value);
 digitalWrite(tinySPI::SS, HIGH);
 // delay (1);
 }  // end of loop
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Why do you want to go to ATtiny?
Tom... :slight_smile:
TomGeorge:
OR
Thanks Tom. I was making the adjust at the same time you wrote your reply :slight_smile:
The code is now in a code box.
Why a ATTiny? Well, it is a small 8 pin dil which makes the product i try to develop, very small. And it looks more professional the a Nano.
Why do you ask? Do you have a better suggestion? I am always open for them :slight_smile:
Thanks!
help......
MCP4921 talk SPI
Have you got the 4921 working with the Nano first?
What you're trying to do looks very strange. Does it even compile?
It looks like you're trying to use a method transfer() from a class named tinySPI. But, then you implement that function yourself. Is this the tinySPI you're trying to use: tinySPI/tinySPI.h at master · JChristensen/tinySPI · GitHub?
If so, study the example code that comes with it.
