Hello! I am new to Arduino (no coding knowledge yet except simple commands), and I needed some help with a code. I am making a machine that lets me know when my laundry basket is full by a weight sensor, among other things. I am having the code turn on a light (which I have already figured out) and play a sound. The issue is ( I think) that the audio is playing every time the code loops. It is only playing a little bit of the file. When the scale senses the weight to be above x, it will play the entire sound file but the main issue is the looping bit. I will include the code below (I apologize that the code is muddled and I know that you are not usually supposed to do multiple things.) Thanks for everything!
code
#include <SD.h> // need to include the SD library
#define SD_ChipSelectPin 10 //connect pin 4 of arduino to cs pin of sd card
#include <TMRpcm.h> //Arduino library for asynchronous playback of PCM/WAV files
#include <SPI.h> // need to include the SPI library
#include "HX711.h"
#define calibration_factor 11760 //This value is obtained using the SparkFun_HX711_Calibration sketch
#define LOADCELL_DOUT_PIN 18
#define LOADCELL_SCK_PIN 19
int LEDL = 16;
HX711 scale;
#include <LiquidCrystal.h>
#include "DHT.h"
#define DHTPIN 8
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
TMRpcm tmrpcm; // create an object for use in this sketch
int temp = 1;
unsigned long previousMillis1 = 0;
const long interval1 = 86400000;
unsigned long previousMillis2 = 0;
const long interval2 = 86400000;
int LED = 17;
int reed_switch1 = 15;
int reed_switch2 = 14;
int reed_status1;
int reed_status2;
int timer = 0;
bool state = 0;
pinMode(LEDL, OUTPUT);
Serial.println("HX711 scale demo");
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
Serial.println("Readings:");
lcd.begin(16, 2);
dht.begin();
tmrpcm.speakerPin = 9; //5,6,11 or 46 on Mega, 9 on Uno, Nano, etc
if (!SD.begin(SD_ChipSelectPin)) // returns 1 if the card is present
Serial.println("SD fail");
return;
pinMode(LED, OUTPUT);
pinMode(reed_switch1, INPUT);
pinMode(reed_switch2, INPUT);
Serial.print("Reading: ");
Serial.print(scale.get_units(), 1); //scale.get_units() returns a float
Serial.print(" lbs"); //You can change this to kg but you'll need to refactor the calibration_factor
{ if (scale.get_units() < 5.0) {
digitalWrite(LEDL, LOW);
tmrpcm.play("basket.wav");
else {
digitalWrite (LEDL, HIGH);
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// read humidity
float h = dht.readHumidity();
//read temperature in Fahrenheit
float f = dht.readTemperature(true);
if (isnan(h) || isnan(f)) {
lcd.print("ERROR");
return;
lcd.setCursor(0, 0);
lcd.print("F:");
lcd.print(f);
lcd.setCursor(9, 0);
lcd.print("H:");
lcd.print(h);
unsigned long currentMillis1 = millis();
reed_status1 = digitalRead(reed_switch1);
// if the LED is off turn it on and vice-versa:
if (reed_status1 == 0) {
while (currentMillis1 - previousMillis1 >= interval1) {
previousMillis1 = currentMillis1;
digitalWrite(LED, HIGH);
if (reed_status1 == 1)
digitalWrite(LED, LOW);
tmrpcm.play("drawer.wav");
