Am using l293dne ic with arduino to control a motor.Could you please go through my code and help me out
//Motor A
const int motorpin1 = 6; // Pin 6 of L293
const int motorpin2 = 9; // Pin 3 of L293
pinMode(motorpin1, OUTPUT);
pinMode(motorpin2, OUTPUT);
digitalWrite(motorpin1, LOW);
digitalWrite(motorpin2, LOW);
void loop(){
if(Serial.available()>0)
char incomingByte = Serial.read();
Serial.println(incomingByte);
if(incomingByte=='a'){
delay(200);
digitalWrite(motorpin2, HIGH);
Serial.println("one way");
else if(incomingByte=='s'){
delay(200);
digitalWrite(motorpin1, HIGH);
Serial.println("other way");
else{
If we input "a" in the serial monitor the motor should rotate in one direction and if we input "s" the motor should rotate in another direction but it is not happening the motor is idle but i get the output on serial monitor like this:
a
one way
s
other way
There is no problem with hardware connections.
Could you please help me with this.Thanks in advance
