This is the error I get when trying to format the code. This is occurring on three machines, all Linux MINT but different versions. Two on this version 22.1 64 Bit. and one earlier version. Sorry I do not do Java, only drink it.
Exception in thread "AWT-EventQueue-0" java.lang.UnsatisfiedLinkError: 'java.lang.String cc.arduino.packages.formatter.AStyleInterface.AStyleMain(java.lang.String, java.lang.String)'
at cc.arduino.packages.formatter.AStyleInterface.AStyleMain(Native Method)
at cc.arduino.packages.formatter.AStyle.run(AStyle.java:80)
at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:318)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:773)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:720)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:714)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:400)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Thanks for the help, hopefully we can get it. Other programs are using java without a problem.
To save space, I used the Blink sketch. The issue occurs regardless of the source file, but otherwise, things are working fairly well compiles are fast and there are no other problems, aside from my own mistakes.
It happens on another machine too, with the same OS and release, though that system has 6 cores instead of 8. The Arduino versions and OS are the same, but both were installed from different sources.
If it helps: the Arduino IDE 2.x version eventually gets stuck in the zooming animation sometimes on the first attempt, other times after 20 or more but at least it consistently exhibits this behavior.
Here is the blink code and errors it generated but object file is ok.
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
https://www.arduino.cc/en/Tutorial/BuiltInExamples/Blink
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
and the errors ---------------------
Exception in thread "AWT-EventQueue-0" java.lang.ArithmeticException: / by zero
at org.fife.ui.rsyntaxtextarea.SyntaxView.viewToModel(SyntaxView.java:940)
at java.desktop/javax.swing.plaf.basic.BasicTextUI$RootView.viewToModel(BasicTextUI.java:1653)
at java.desktop/javax.swing.plaf.basic.BasicTextUI.viewToModel(BasicTextUI.java:1180)
at java.desktop/javax.swing.plaf.basic.BasicTextUI.viewToModel(BasicTextUI.java:1160)
at java.desktop/javax.swing.plaf.basic.BasicTextUI.viewToModel(BasicTextUI.java:1137)
at java.desktop/javax.swing.text.JTextComponent.viewToModel(JTextComponent.java:1432)
at org.fife.ui.rsyntaxtextarea.RSyntaxTextArea.viewToToken(RSyntaxTextArea.java:3058)
at processing.app.syntax.SketchTextArea$SketchTextAreaMouseListener.mouseMoved(SketchTextArea.java:274)
at java.desktop/java.awt.AWTEventMulticaster.mouseMoved(AWTEventMulticaster.java:338)
at java.desktop/java.awt.AWTEventMulticaster.mouseMoved(AWTEventMulticaster.java:337)
at java.desktop/java.awt.Component.processMouseMotionEvent(Component.java:6666)
at java.desktop/javax.swing.JComponent.processMouseMotionEvent(JComponent.java:3416)
at java.desktop/java.awt.Component.processEvent(Component.java:6390)
at java.desktop/java.awt.Container.processEvent(Container.java:2266)
at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:4996)
at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2324)
at java.desktop/java.awt.Component.dispatchEvent(Component.java:4828)
at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4948)
at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4588)
at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4516)
at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2310)
at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2780)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:775)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:98)
at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:747)
at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:744)
The best I can guess is the Arduino IDE failed to call the AStyle code formatter.
We received a report that this problem occurs when you are using a 3rd party package of Arduino IDE 1.x from the package repository:
The package maintainers tend to make unspecified modifications to the IDE, which results in problems that are specific to using the package rather than universal to the IDE application in general.
The solution is to use the official build of Arduino IDE that is distributed by the Arduino company. You can download it from the links on the "Software" page here:
