I have function that takes 5 arguments.
I have a large array that holds the arguments in sets of 5. Like this - I have just shown for 3 sets
float param[100] = { 2,0.5,4.5,0.0,5.0
2,4.5,0.5,0.0,5.0
3,2.5,2.5,0.0,5.0 };
So the function inside the loop() will use the first set of arguments , complete something and then will need to fetch the next set of 5 arguments and work on that, till the complete set of arguments are used up.
Will be happy to get some ideas to do this.
Why not use a two dimensional array?
Not quite like that I hope. You have commas missing
I agree with AWOL. Use a 2 dimensional array, or just pretend that it is a 2 dimensional array and do this
float param[100] = {2, 0.5, 4.5, 0.0, 5.0,
2, 4.5, 0.5, 0.0, 5.0,
3, 2.5, 2.5, 0.0, 5.0
for (int set = 0; set < 3; set++)
for (int member = 0; member < 5; member++)
Serial.print(param[set * 5 + member]);
Serial.print("\t");
Honestly never thought of that ! Let me try and work on it !! Thanks
Thanks ... yes this is possible when i know beforehand the number of data sets. Maybe I need to tweak this to exit the loop upon meeting a particular end marker character ! Maybe a float that is way out of the expected data range .
There is no way to make an array of constants WITHOUT knowing the number of data sets.
float param[][5] =
{2, 0.5, 4.5, 0.0, 5.0},
{2, 4.5, 0.5, 0.0, 5.0},
{3, 2.5, 2.5, 0.0, 5.0}
size_t paramCount = sizeof param / sizeof param[0];
for (size_t set = 0; set < paramCount; set++)
for (size_t member = 0; member < 5; member++)
Serial.print(param[set][member]);
Serial.print("\t");
If I find myself passing five arguments to a function, I start thinking of ways to reduce that number. It's far too easy in a language like C++ that doesn't have named arguments to accidentally swap arguments.
Consider passing a struct or a class as a parameter and using a array of structs/classes instead.
